주요 콘텐츠로 건너뛰기
IBM ThinkPad t43 WiFi Card Replacement
필요한 것
  1. IBM ThinkPad t43 WiFi Card Replacement, WiFi Card: 1 단계, 이미지 1/2 IBM ThinkPad t43 WiFi Card Replacement, WiFi Card: 1 단계, 이미지 2/2
    • Start with the laptop with the side with the logo facing down.
    • Next you will have to remove all the screws in the red circles
    • When removing the screws try to place them in order of removal on a magnetic pad. It will help when you put them back and lowers the chance of losing them
  2. IBM ThinkPad t43 WiFi Card Replacement: 2 단계, 이미지 1/2 IBM ThinkPad t43 WiFi Card Replacement: 2 단계, 이미지 2/2
    • Flip the laptop so that the logo is now facing up
    • locate the lock switch on the front right
    • Slide the switch to the right to unlock the laptop
    • Make sure to unlock the laptop before opening because the keyboard may still be attached
  3. IBM ThinkPad t43 WiFi Card Replacement: 3 단계, 이미지 1/2 IBM ThinkPad t43 WiFi Card Replacement: 3 단계, 이미지 2/2
    • Lift open the laptop
    • The keyboard should be detached from the bottom part of the laptop
    • Hold the edges of the keyboard and slowly pull up until it opens
    • Do not pull off the keyboard completely because there is a ribbon cable attached
  4. IBM ThinkPad t43 WiFi Card Replacement: 4 단계, 이미지 1/2 IBM ThinkPad t43 WiFi Card Replacement: 4 단계, 이미지 2/2
    • Disconnect the ribbon cable by simply lifting it up
  5. IBM ThinkPad t43 WiFi Card Replacement: 5 단계, 이미지 1/1
    • The WiFi-Card is located towards the middle bottom of the laptop
  6. IBM ThinkPad t43 WiFi Card Replacement: 6 단계, 이미지 1/2 IBM ThinkPad t43 WiFi Card Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Locate the two wires connected at the top of the WiFi-Card
    • Hold the card down and use the tweezers to pinch the plug and pull up.
  7. IBM ThinkPad t43 WiFi Card Replacement: 7 단계, 이미지 1/3 IBM ThinkPad t43 WiFi Card Replacement: 7 단계, 이미지 2/3 IBM ThinkPad t43 WiFi Card Replacement: 7 단계, 이미지 3/3
    • Place fingers on the two clips holding the card in place
    • Pull the clips outwards until the the card pops up
    • Pull the card out by pulling out away from your body
    • To replace, follow these steps in reverse order
    • Make sure that the side with the short end is on the left when you put it back in.
결론
다른 2명이 해당 안내서를 완성하였습니다.
aLiX pIeRRe
회원 가입일: 03/19/18
855 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 UMass Dartmouth, Team S6-G4, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G4
4 회원들
안내서 10개 작성하였습니다
댓글 2개
I need to know what's role of the cables AUX and MAIN because i cut one
M a n i _001 - 답글
AUX and MAIN cables are antenna cables. In this laptop there are two antennas, MAIN and AUX.
If you have a soldering iron, simply solder the two parts of the cable you cut and everything is gonna be fine.
I also recommend using shrink tubing to isolate the soldered part.
Note : laptop can work without this câble, but WiFi speed and stability will suffer.
If you can't solder the câble or can't by a new one, you can try to use only main by pluggin the only remaining antena câble to MAIN and leaving AUX unlpuged.
Brendan -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 39
30일 전: 154
전체 시간: 10,523
