주요 콘텐츠로 건너뛰기
IQ America VD-8810L Motherboard Replacement
필요한 것
  1. IQ America VD-8810L Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 IQ America VD-8810L Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 IQ America VD-8810L Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Wedge the spudger into the slot of the panel on the bottom of the device.
    • Rotate out the panel to reveal the screw holding the device together.
  2. IQ America VD-8810L Motherboard Replacement: 2 단계, 이미지 1/2 IQ America VD-8810L Motherboard Replacement: 2 단계, 이미지 2/2
    • Use the Phillips head screwdriver to remove the screw.
    • Separate the Top and bottom halves of the device.
  3. IQ America VD-8810L Motherboard Replacement: 3 단계, 이미지 1/3 IQ America VD-8810L Motherboard Replacement: 3 단계, 이미지 2/3 IQ America VD-8810L Motherboard Replacement: 3 단계, 이미지 3/3
    • Remove batteries from the battery slot.
    • Unscrew the two Phillips head screws in the center of the battery slot.
    • Unscrew the remaining two screws at the bottom of the unit using the 3.0 triangle head screwdriver.
  4. IQ America VD-8810L Motherboard Replacement: 4 단계, 이미지 1/1
    • Use the spudger to separate the top and bottom halves of the screen.
  5. IQ America VD-8810L Motherboard Replacement: 5 단계, 이미지 1/1
    • Disconnect the wires from the green motherboard to the bottom half by pulling apart the connecting pins.
  6. IQ America VD-8810L Motherboard Replacement: 6 단계, 이미지 1/3 IQ America VD-8810L Motherboard Replacement: 6 단계, 이미지 2/3 IQ America VD-8810L Motherboard Replacement: 6 단계, 이미지 3/3
    • Unscrew all 3 Phillips head screws on the outside edges of the motherboard.
  7. IQ America VD-8810L Motherboard Replacement: 7 단계, 이미지 1/1
    • Carefully remove the microphone from the casing by pulling away from the device.
  8. IQ America VD-8810L Motherboard Replacement: 8 단계, 이미지 1/2 IQ America VD-8810L Motherboard Replacement: 8 단계, 이미지 2/2
    • Gently lift the motherboard from the casing to reveal the speaker.
    • Unscrew the two Phillips head screws that hold the speaker in place.
  9. IQ America VD-8810L Motherboard Replacement: 9 단계, 이미지 1/1
    • Refer to this guide to desolder the speaker from the motherboard.
결론
Jackey Lau
회원 가입일: 10/17/17
301 평판
안내서 3개 작성하였습니다
UC Santa Barbara, Team S1-G3, Weedon Fall 2017 UC Santa Barbara, Team S1-G3, Weedon Fall 2017 회원
UCSB-WEEDON-F17S1G3
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 241
