주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Imation Superdisk USB Drive Disc Drive Casing Replacement
필요한 것
  1. Imation Superdisk USB Drive Disc Drive Casing Replacement, Plastic Housing: 1 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Plastic Housing: 1 단계, 이미지 2/2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Disc Drive Casing Replacement: 2 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 2 단계, 이미지 2/2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Disc Drive Casing Replacement: 3 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 3 단계, 이미지 2/2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Disc Drive Casing Replacement: 4 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 4 단계, 이미지 2/2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Disc Drive Casing Replacement: 5 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 5 단계, 이미지 2/2
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Disc Drive Casing Replacement: 6 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 6 단계, 이미지 2/2
    • Slide the metal housing out of the plastic shell.
  7. Imation Superdisk USB Drive Disc Drive Casing Replacement, Metal Casing: 7 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Metal Casing: 7 단계, 이미지 2/2
    • Slide metal panel out of the metal casing.
  8. Imation Superdisk USB Drive Disc Drive Casing Replacement: 8 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 8 단계, 이미지 2/2
    • Slide disk drive out of metal casing.
  9. Imation Superdisk USB Drive Disc Drive Casing Replacement, Daughter Board: 9 단계, 이미지 1/1
    • Flip the disk drive over so the the plug on the daughter board is visible.
  10. Imation Superdisk USB Drive Disc Drive Casing Replacement: 10 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 10 단계, 이미지 2/2
    • Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
  11. Imation Superdisk USB Drive Disc Drive Casing Replacement: 11 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 11 단계, 이미지 2/2
    • Gently pull on the daughter board until it separates from the device.
  12. Imation Superdisk USB Drive Disc Drive Casing Replacement, Disc Drive Casing: 12 단계, 이미지 1/2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Disc Drive Casing: 12 단계, 이미지 2/2
    • Place a plastic spudger in between the disk drive and its metal casing. Use the spudger as a lever the until the metal casing detaches from the disk drive.
    • You may have to use the plastic spudger in several spots along the metal casing.
  13. Imation Superdisk USB Drive Disc Drive Casing Replacement: 13 단계, 이미지 1/1
    • lift the disk drive completely out of the metal casing and set it aside.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Caitlin Horwatt
회원 가입일: 02/11/14
137 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-2, Buehl Spring 2014 Ohio State, Team 1-2, Buehl Spring 2014 회원
OSU-BUEHL-S14S1G2
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
Does anyone know if the MAC USB version works on modern PCs?
davidpaulpeterson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 592
