주요 콘텐츠로 건너뛰기
Infant Optics DXR-8 Monitor Motherboard Replacement
필요한 것
  1. Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: 1 단계, 이미지 1/3 Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: 1 단계, 이미지 2/3 Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: 1 단계, 이미지 3/3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Monitor Motherboard Replacement: 2 단계, 이미지 1/3 Infant Optics DXR-8 Monitor Motherboard Replacement: 2 단계, 이미지 2/3 Infant Optics DXR-8 Monitor Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Monitor Motherboard Replacement: 3 단계, 이미지 1/3 Infant Optics DXR-8 Monitor Motherboard Replacement: 3 단계, 이미지 2/3 Infant Optics DXR-8 Monitor Motherboard Replacement: 3 단계, 이미지 3/3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: 4 단계, 이미지 1/3 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: 4 단계, 이미지 2/3 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: 4 단계, 이미지 3/3
    • Using a plastic opening tool, disconnect the ribbon cable connector.
    • Gently separate the ribbon cable from the motherboard.
  5. Infant Optics DXR-8 Monitor Motherboard Replacement: 5 단계, 이미지 1/2 Infant Optics DXR-8 Monitor Motherboard Replacement: 5 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
    • Flip the motherboard away from the front case to reveal the screen on the other side.
  6. Infant Optics DXR-8 Monitor Motherboard Replacement: 6 단계, 이미지 1/1
    • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
  7. Infant Optics DXR-8 Monitor Motherboard Replacement: 7 단계, 이미지 1/3 Infant Optics DXR-8 Monitor Motherboard Replacement: 7 단계, 이미지 2/3 Infant Optics DXR-8 Monitor Motherboard Replacement: 7 단계, 이미지 3/3
    • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
    • Lift the screen off of the motherboard.
  8. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: 8 단계, 이미지 1/2 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: 8 단계, 이미지 2/2
    • Flip the motherboard away from the case.
    • Using a soldering iron and desoldering braid, desolder the antenna from the motherboard.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James McNeil
회원 가입일: 09/17/20
400 평판
안내서 2개 작성하였습니다
댓글 2개
Can you do one for the DXR-8 Pro monitor? Mine randomly stoped turning on and I want to see if I can open it up and try to fix it.
Andfel - 답글
Can you please tell me where to buy a replacement motherboard??
Ilya Nechay - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 28
전체 시간: 1,178
