소개
If the monitor of the Infant Optics DXR-8 is not functioning properly, the motherboard may be faulty. Follow these instructions to replace the motherboard in the monitor.
필요한 것
Using the plastic opening tool, remove screen protector from front of monitor.
Using a plastic opening tool, disconnect the ribbon cable connector.
Gently separate the ribbon cable from the motherboard.
Flip the motherboard away from the case.
Using a soldering iron and desoldering braid, desolder the antenna from the motherboard.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Can you please tell me where to buy a replacement motherboard??
