주요 콘텐츠로 건너뛰기
Insignia Flex 10.1 NS-P16AT10 Battery Replacement
필요한 것
  1. Insignia Flex 10.1 NS-P16AT10 Battery Replacement, Battery: 1 단계, 이미지 1/2 Insignia Flex 10.1 NS-P16AT10 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure your device is off and not connected to any power sources to avoid injury
    • Use a plastic opening tool to remove the rear panel from the front case.
    • Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
    • Work the tool around the perimeter of the device until the front and rear panels become separate.
    • The volume rocker and power button will become free from the device when the front and rear panels are separated from each other. Do not worry. These pieces are easily put back into place when reassembling the tablet.
  2. Insignia Flex 10.1 NS-P16AT10 Battery Replacement: 2 단계, 이미지 1/2 Insignia Flex 10.1 NS-P16AT10 Battery Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to flip the ribbon connector up in order to free the ribbon cable from the motherboard.
  3. Insignia Flex 10.1 NS-P16AT10 Battery Replacement: 3 단계, 이미지 1/3 Insignia Flex 10.1 NS-P16AT10 Battery Replacement: 3 단계, 이미지 2/3 Insignia Flex 10.1 NS-P16AT10 Battery Replacement: 3 단계, 이미지 3/3
    • Free the battery from the motherboard by desoldering the red, white, and black connections one by one.
    • For soldering instructions, visit this guide.
    • Remove the soldering tip immediately once the wire has become free. Too much heat can damage the motherboard.
  4. Insignia Flex 10.1 NS-P16AT10 Battery Replacement: 4 단계, 이미지 1/1
    • Peel the black tape up that is attached to the battery and front case.
  5. Insignia Flex 10.1 NS-P16AT10 Battery Replacement: 5 단계, 이미지 1/2 Insignia Flex 10.1 NS-P16AT10 Battery Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to remove the battery from the front case.
    • Place the plastic opening tool between the battery and front case. Work the tool around the perimeter of the battery until the battery is free.
    • Do not bend or puncture the battery, or the battery will leak.
  6. Insignia Flex 10.1 NS-P16AT10 Battery Replacement: 6 단계, 이미지 1/2 Insignia Flex 10.1 NS-P16AT10 Battery Replacement: 6 단계, 이미지 2/2
    • The battery is now removed from the device. Replace the battery.
결론
Morgan Kidd
회원 가입일: 10/10/16
419 평판
안내서 3개 작성하였습니다
Texas Tech, Team 12-3, Bennett Fall 2016 Texas Tech, Team 12-3, Bennett Fall 2016 회원
TTU-BENNETT-F16S12G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 10
전체 시간: 693
