주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If your Insignia Flex 11.6 is not holding a charge or is not starting up, use this guide in replacing the battery.
  1. Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury. Detach the keyboard from the screen in 2 different places by putting one hand on the keyboard while gently pulling up on the screen with the other hand. Detach the keyboard from the screen in 2 different places by putting one hand on the keyboard while gently pulling up on the screen with the other hand.
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Detach the keyboard from the screen in 2 different places by putting one hand on the keyboard while gently pulling up on the screen with the other hand.
  2. Remove the two 6.1 mm Phillips J000 screws from the bottom of the device.  Use Phillips Screwdriver size J1. If any screws are stripped, refer to the iFixit guide for how to remove a stripped screw.
    • Remove the two 6.1 mm Phillips J000 screws from the bottom of the device. Use Phillips Screwdriver size J1.
    • If any screws are stripped, refer to the iFixit guide for how to remove a stripped screw.
  3. Using a plastic opening tool, gently pry off the back cover. Using a plastic opening tool, gently pry off the back cover. Using a plastic opening tool, gently pry off the back cover.
    • Using a plastic opening tool, gently pry off the back cover.
  4. Remove the electrical connector that connects to the battery to remove the power to the battery. Remove the electrical connector that connects to the battery to remove the power to the battery. Remove the electrical connector that connects to the battery to remove the power to the battery.
    • Remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Make sure not to bend the battery too excessively as if bent too much, it could rupture a cell within the battery and possibly cause a fire. The battery is glued onto the device. To remove it, use a nylon spudger or plastic card to slide underneath the battery and scrape back and forth to remove the glue until the battery is removed from the device. The battery is glued onto the device. To remove it, use a nylon spudger or plastic card to slide underneath the battery and scrape back and forth to remove the glue until the battery is removed from the device.
    • Make sure not to bend the battery too excessively as if bent too much, it could rupture a cell within the battery and possibly cause a fire.
    • The battery is glued onto the device. To remove it, use a nylon spudger or plastic card to slide underneath the battery and scrape back and forth to remove the glue until the battery is removed from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Connor Sweeney
회원 가입일: 2016년 09월 28일
404 평판
안내서 5개 작성하였습니다
Donde puedo adquirir la batería?
arag12 - 답글
There are no screws on the bottom edge of my invicta model P11A8100. Can I bypass removing screws and proceed to removing the back?
Robert Sandfort - 답글
There are no screws on the bottom of my model P11A8100. Can I bypass removal is said screws and proceed to opening the back?
Great instructions but I cant find a battery replacement. Battery number 3394122-2p
Hank Drabczak - 답글
Great instructions but now I cant find the battery anywhere it is 3394122-2p
Hank Drabczak - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 26
전체 시간: 3,761
