주요 콘텐츠로 건너뛰기
Insignia Flex 11.6 Screen Replacement
필요한 것
  1. Insignia Flex 11.6 Screen Replacement, Power Removal: 1 단계, 이미지 1/3 Insignia Flex 11.6 Screen Replacement, Power Removal: 1 단계, 이미지 2/3 Insignia Flex 11.6 Screen Replacement, Power Removal: 1 단계, 이미지 3/3
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Screen Replacement: 2 단계, 이미지 1/2 Insignia Flex 11.6 Screen Replacement: 2 단계, 이미지 2/2
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. 마모된 나사 분리 방법
  3. Insignia Flex 11.6 Screen Replacement: 3 단계, 이미지 1/3 Insignia Flex 11.6 Screen Replacement: 3 단계, 이미지 2/3 Insignia Flex 11.6 Screen Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Screen Replacement: 4 단계, 이미지 1/3 Insignia Flex 11.6 Screen Replacement: 4 단계, 이미지 2/3 Insignia Flex 11.6 Screen Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Screen Replacement, Motherboard: 5 단계, 이미지 1/1
    • Unplug the 2 speaker's connection from the motherboard.
  6. Insignia Flex 11.6 Screen Replacement: 6 단계, 이미지 1/2 Insignia Flex 11.6 Screen Replacement: 6 단계, 이미지 2/2
    • Peel the yellow tape off from on top of the electrical connectors.
  7. Insignia Flex 11.6 Screen Replacement: 7 단계, 이미지 1/2 Insignia Flex 11.6 Screen Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Flip up the black cover pieces to expose the 3 electrical connectors.
    • Remove 3 electrical connectors by gently pulling back on them with some tweezers.
  8. Insignia Flex 11.6 Screen Replacement: 8 단계, 이미지 1/3 Insignia Flex 11.6 Screen Replacement: 8 단계, 이미지 2/3 Insignia Flex 11.6 Screen Replacement: 8 단계, 이미지 3/3
    • Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
    • Remove the black camera connector by gently prying on it until it unhooks.
  9. Insignia Flex 11.6 Screen Replacement: 9 단계, 이미지 1/2 Insignia Flex 11.6 Screen Replacement: 9 단계, 이미지 2/2
    • Using tweezers, remove the microphone from the the plastic cover.
  10. Insignia Flex 11.6 Screen Replacement: 10 단계, 이미지 1/1
    • Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
    • Motherboard pops out.
  11. Insignia Flex 11.6 Screen Replacement, Screen: 11 단계, 이미지 1/3 Insignia Flex 11.6 Screen Replacement, Screen: 11 단계, 이미지 2/3 Insignia Flex 11.6 Screen Replacement, Screen: 11 단계, 이미지 3/3
    • Remove battery by prying off with card.
  12. Insignia Flex 11.6 Screen Replacement: 12 단계, 이미지 1/2 Insignia Flex 11.6 Screen Replacement: 12 단계, 이미지 2/2
    • Peel back the copper color electrical connector with blue opening tool.
  13. Insignia Flex 11.6 Screen Replacement: 13 단계, 이미지 1/1
    • Remove 12 - 4.15mm J000 Phillips screws from the metal bracket.
    • Bracket will then come off.
  14. Insignia Flex 11.6 Screen Replacement: 14 단계, 이미지 1/1
    • Remove 1 - 3.4 mm J000 Phillips screw from metal plate bracket.
  15. Insignia Flex 11.6 Screen Replacement: 15 단계, 이미지 1/2 Insignia Flex 11.6 Screen Replacement: 15 단계, 이미지 2/2
    • Remove screen from case by prying with a card.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Connor Sweeney
회원 가입일: 09/28/16
479 평판
안내서 5개 작성하였습니다
댓글 6개
The Flex 11.6" Model# NS-P11W7100 DOEST HAVE THOSE SCREWS RIGHT THERE!!!!!
Charles Kinnison - 답글
yeah, thats the one I have. its quite a bit different. the speaker wires are soldered, too…
Joshua Francis -
mine doesn’t look like that…
Joshua Francis - 답글
where can i get a new screen to buy?
florence sefaa - 답글
Do you sell the insignia ns-p11w7100 tablet 11.6 inches screen? I need on to fix my broken part.
florence sefaa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 15
전체 시간: 4,501
