주요 콘텐츠로 건너뛰기
Insignia NS-15MS0832B Battery Replacement
필요한 것
  1. Insignia NS-15MS0832B Battery  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Begin the replacement for the battery by opening up the device with a plastic opening tool along the edge.
    • Work the plastic opening tool along the edge until you have separated the screen from the back plate.
  2. Insignia NS-15MS0832B Battery  Replacement: 2 단계, 이미지 1개 중 1개
    • Your tablet should look like this once separated.
  3. Insignia NS-15MS0832B Battery  Replacement: 3 단계, 이미지 1개 중 1개
    • Start by placing tablet face down and carefully removing the mesh wire tap from the back of the battery.
  4. Insignia NS-15MS0832B Battery  Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the flat wire from its connector with the tweezers and fold to the side so that it's clear of the battery.
  5. Insignia NS-15MS0832B Battery  Replacement: 5 단계, 이미지 1개 중 1개
    • Next locate where the battery has three wires attached to the mother board. Take out the soldering iron and begin heating it up.
    • Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
  6. Insignia NS-15MS0832B Battery  Replacement: 6 단계, 이미지 1개 중 1개
    • Once the soldering iron has heated up, begin by placing the tip of the iron where the wire directly meets the mother board. The soldering should heat up and allow you to gently pull the wire off. Repeat twice more to remove each of the three wires.
  7. Insignia NS-15MS0832B Battery  Replacement: 7 단계, 이미지 1개 중 1개
    • Once all wires have been removed from mother board, take plastic opening tool and separate the battery from the back of the screen. Its connected with glue, so don't worry.
  8. Insignia NS-15MS0832B Battery  Replacement: 8 단계, 이미지 1개 중 1개
    • Remove battery and replace faulty one with new battery.
결론
To reassemble your Insignia W-Fi Windows 8" Tablet, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Harrison Smith
회원 가입일: 10/19/16
329 평판
안내서 3개를 작성함
Texas Tech, Team 1-1, Bennett Fall 2016 Texas Tech, Team 1-1, Bennett Fall 2016 회원
TTU-BENNETT-F16S1G1
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 1,224
