주요 콘텐츠로 건너뛰기
Insignia NS-CSPBTHOL-R Buttons Replacement
필요한 것
  1. Insignia NS-CSPBTHOL-R Buttons Replacement, Buttons: 1 단계, 이미지 1/2 Insignia NS-CSPBTHOL-R Buttons Replacement, Buttons: 1 단계, 이미지 2/2
    • Use the spudger to pry off the plastic grate covering the speakers, then gently pull it off with your fingers.
  2. Insignia NS-CSPBTHOL-R Buttons Replacement: 2 단계, 이미지 1/1
    • once the grate has been removed, Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  3. Insignia NS-CSPBTHOL-R Buttons Replacement: 3 단계, 이미지 1/1
    • Insert the Spudger between the corners of base and the face of the speaker to open the device. The screw on the upper right corner may be difficult to take out. If you cannot take it out with a screwdriver, using force to pull the face of the speaker apart may break the plastic that surrounds the screw.
  4. Insignia NS-CSPBTHOL-R Buttons Replacement: 4 단계, 이미지 1/3 Insignia NS-CSPBTHOL-R Buttons Replacement: 4 단계, 이미지 2/3 Insignia NS-CSPBTHOL-R Buttons Replacement: 4 단계, 이미지 3/3
    • Gently pull apart the speaker to separate the speakers from the battery and motherboard. Then pull out the motherboard with your fingers by grabbing the edges and pulling upwards.
  5. Insignia NS-CSPBTHOL-R Buttons Replacement: 5 단계, 이미지 1/2 Insignia NS-CSPBTHOL-R Buttons Replacement: 5 단계, 이미지 2/2
    • Desolder the four contact points from the button that is unresponsive.
    • Check out this helpful guide for soldering and desoldering tips.
결론
Zachary Foltz
회원 가입일: 02/15/17
101 평판
안내서 1개 작성함
USF Tampa, Team 12-6, Eyestone Spring 2017 USF Tampa, Team 12-6, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 13
전체 시간: 344
