주요 콘텐츠로 건너뛰기
Insignia NS-PLTPSP13 Circuit Board Replacement
필요한 것
  1. Insignia NS-PLTPSP13 Circuit Board Replacement, Insignia NS-PLTPSP13 Disassembly: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to lift the corner of the mesh until a gap is created.
  2. Insignia NS-PLTPSP13 Circuit Board Replacement: 2 단계, 이미지 1/2 Insignia NS-PLTPSP13 Circuit Board Replacement: 2 단계, 이미지 2/2
    • Once there is a gap big enough, insert the metal spudger, and remove the tweezers.
  3. Insignia NS-PLTPSP13 Circuit Board Replacement: 3 단계, 이미지 1/3 Insignia NS-PLTPSP13 Circuit Board Replacement: 3 단계, 이미지 2/3 Insignia NS-PLTPSP13 Circuit Board Replacement: 3 단계, 이미지 3/3
    • Now take the size J0 JIS screwdriver to remove the seven 5 mm screws on the plastic casing of the speaker.
    • Do not forget about the 5mm screw on the backside of the speaker, it may be covered by a white sticker, and it will prevent you from removing the plastic cover.
  4. Insignia NS-PLTPSP13 Circuit Board Replacement: 4 단계, 이미지 1/2 Insignia NS-PLTPSP13 Circuit Board Replacement: 4 단계, 이미지 2/2
    • Once all seven 5mm screws are taken off use the metal spudger again to pry off the plastic casing from the speaker.
  5. Insignia NS-PLTPSP13 Circuit Board Replacement: 5 단계, 이미지 1/2 Insignia NS-PLTPSP13 Circuit Board Replacement: 5 단계, 이미지 2/2
    • To further take apart the speaker, there are also two 5mm screws on the green circuit board which keep the speaker and circuit board attached. Unscrew these with the size J0 JIS screwdriver.
  6. Insignia NS-PLTPSP13 Circuit Board Replacement, Circuit Board: 6 단계, 이미지 1/2 Insignia NS-PLTPSP13 Circuit Board Replacement, Circuit Board: 6 단계, 이미지 2/2
결론
Matt Mrazik
회원 가입일: 03/22/17
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S4-G2, Julie Spring 2017 UMass Dartmouth, Team S4-G2, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G2
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 8
전체 시간: 309
