주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Install macOS Printer Drivers
  1. Install macOS Printer Drivers, Install macOS Printer Drivers: 1 단계, 이미지 2개 중 1개 Install macOS Printer Drivers, Install macOS Printer Drivers: 1 단계, 이미지 2개 중 2개
    • Find the driver for your printer brand on the link below:
    • https://support.apple.com/kb/index?page=...
    • Download the driver for your printer, by clicking on the "Download" button.
    • If the message: "This connection is not private" appears, open the page with the private mode of your browser.
    댓글 쓰기
  2. Install macOS Printer Drivers: 2 단계, 이미지 2개 중 1개 Install macOS Printer Drivers: 2 단계, 이미지 2개 중 2개
    • Open your .dmg file
    • Open your .pkg file
    • If this message appears: "This update requires macOS 12.0 or earlier." click Close and continue with the next step.
    • Otherwise, continue with step 7.
    댓글 쓰기
  3. Install macOS Printer Drivers: 3 단계, 이미지 3개 중 1개 Install macOS Printer Drivers: 3 단계, 이미지 3개 중 2개 Install macOS Printer Drivers: 3 단계, 이미지 3개 중 3개
    • Move your .pkg file to your desktop
    • Open Terminal
    • Enter: cd Desktop/ then press the Enter key
    댓글 쓰기
  4. Install macOS Printer Drivers: 4 단계, 이미지 3개 중 1개 Install macOS Printer Drivers: 4 단계, 이미지 3개 중 2개 Install macOS Printer Drivers: 4 단계, 이미지 3개 중 3개
    • Enter the following command: pkgutil --expand FileName.pkg FileName
    • Change FileName to the name of your file, in both places.
    • Then press the Enter key.
    • A folder with the file name appears on your desktop.
    • Open the folder.
    댓글 쓰기
  5. Install macOS Printer Drivers: 5 단계, 이미지 2개 중 1개 Install macOS Printer Drivers: 5 단계, 이미지 2개 중 2개
    • Open the Distribution file with TextEdit
    • Then change the number after (system.compareVersions(system.version.ProductVersion, '12.0')" to that of your macOS version or later.
    • Save the file and close it.
    댓글 쓰기
  6. Install macOS Printer Drivers: 6 단계, 이미지 2개 중 1개 Install macOS Printer Drivers: 6 단계, 이미지 2개 중 2개
    • Return to the Terminal
    • Enter the following command: pkgutil --flatten FileName FileName.pkg and press the Enter key.
    • Close theTerminal and open FileName.pkg on your desktop.
    댓글 쓰기
  7. Install macOS Printer Drivers: 7 단계, 이미지 1개 중 1개
    • Congratulations, you can proceed with the installation by following the steps one by one.
    댓글 쓰기
결론
Congratulations, you made it!
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Anthony Fassler
회원 가입일: 02/26/15
6,989 평판
안내서 4개를 작성함
2가이드 댓글
Merci pour cet excellent tutoriel, j'ai récupéré le fonctionnement de mon ancienne imprimante HP sur mon Mac !
Bravo !!!
Cédric Trocellier - 답글 공유
Bonjours ,j'ai un ordinateur imac et je veux installer une imprimante canon, je dois telecharger un logiciel pour ça et je n'y arrive pas; pouvez vous m'aider svp; merci
Moh Cho - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 118
전체 시간: 5,218
