주요 콘텐츠로 건너뛰기
Installing Hook-and-Loop Tape in Clothing
필요한 것
  1. Installing Hook-and-Loop Tape in Clothing, Installing Hook-and-Loop Tape in Clothing: 1 단계, 이미지 2개 중 1개 Installing Hook-and-Loop Tape in Clothing, Installing Hook-and-Loop Tape in Clothing: 1 단계, 이미지 2개 중 2개
    • Lay your piece of hook-and-loop tape on the fabric where you would like it to live.
    • Pin the hook-and-loop tape into place.
  2. Installing Hook-and-Loop Tape in Clothing: 2 단계, 이미지 2개 중 1개 Installing Hook-and-Loop Tape in Clothing: 2 단계, 이미지 2개 중 2개
    • Position your fabric under the presser foot of your sewing machine in the upper right hand corner of the hook-and-loop tape. Drop the presser foot.
    • Use the balance wheel to sink the needle.
    • The balance wheel should only be turned in the direction that advances the sewing machine. Usually, this means turning the wheel towards you. Turning the wheel in the opposite direction can ruin the tension on the sewing machine, causing it to jam. See your sewing machine manual for instructions specific to your machine.
  3. Installing Hook-and-Loop Tape in Clothing: 3 단계, 이미지 3개 중 1개 Installing Hook-and-Loop Tape in Clothing: 3 단계, 이미지 3개 중 2개 Installing Hook-and-Loop Tape in Clothing: 3 단계, 이미지 3개 중 3개
    • Sew along the edge of the hook-and-loop tape, stopping just at the end.
    • Pull the pin out.
    • When you pull the pin out, be sure the needle is already down. If not, use the balance wheel to sink the needle into the fabric.
  4. Installing Hook-and-Loop Tape in Clothing: 4 단계, 이미지 3개 중 1개 Installing Hook-and-Loop Tape in Clothing: 4 단계, 이미지 3개 중 2개 Installing Hook-and-Loop Tape in Clothing: 4 단계, 이미지 3개 중 3개
    • Lift the presser foot, leaving the needle sunk.
    • Rotate the fabric 90º counterclockwise.
  5. Installing Hook-and-Loop Tape in Clothing: 5 단계, 이미지 2개 중 1개 Installing Hook-and-Loop Tape in Clothing: 5 단계, 이미지 2개 중 2개
    • Lower the presser foot and sew the second side of the hook-and-loop tape.
    • Continue sewing the hook-and-loop tape. When you come to the end of a side, sink the needle into the fabric and lift the presser foot. Then turn the fabric at each of the remaining corners.
  6. Installing Hook-and-Loop Tape in Clothing: 6 단계, 이미지 2개 중 1개 Installing Hook-and-Loop Tape in Clothing: 6 단계, 이미지 2개 중 2개
    • On the last side of the hook-and-loop tape, backstitch over the last few stitches.
  7. Installing Hook-and-Loop Tape in Clothing: 7 단계, 이미지 3개 중 1개 Installing Hook-and-Loop Tape in Clothing: 7 단계, 이미지 3개 중 2개 Installing Hook-and-Loop Tape in Clothing: 7 단계, 이미지 3개 중 3개
    • Clip the threads, freeing the fabric from the sewing machine.
    • Clip the extra thread off.
    • Repeat this guide for the other side of the hook-and-loop tape.
결승점
작성자
5다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
90,451 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 50
지난 30일: 219
전체 시간: 37,221
