소개
At the time of writing this guide, OS X 10.5 Leopard was the current release by Apple. The newest OS by Apple is OS X 10.10 Yosemite. The installation procedure should be relatively the same as previous versions, although, you will need to first create a Yosemite Recovery Disk using this tool.
Install Mac OS X v10.5 Leopard on a new hard drive.
Insert a Mac OS X v10.5 Leopard installation disc into your optical drive.
Hold down the “option” key and restart the computer to bring up the boot option menu.
To begin the installation, click the install disc icon on the boot option menu.
Select your new hard drive from the left column in Disk Utility.
The correct partition table type needs to be set for your hard drive.
If it's a brand-new hard drive, it may have no partition type listed.
For an Intel-based machine, you should have "GUID Partition Table" listed.
For a Power-PC-based machine, you should have "Apple Partition Map" listed.
If the incorrect partition type is listed, proceed to the next step to delete and re-create the partition. If not, proceed to step 8.
Mac OS X Leopard should now be freshly installed. Enjoy!
