주요 콘텐츠로 건너뛰기
Installing a Plastic Snap Using a Hand Press
필요한 것
  1. Installing a Plastic Snap Using a Hand Press, Plastic Snap: 1 단계, 이미지 1/2 Installing a Plastic Snap Using a Hand Press, Plastic Snap: 1 단계, 이미지 2/2
    • Get a new cap.
    • Get a new stud.
  2. Installing a Plastic Snap Using a Hand Press: 2 단계, 이미지 1/1
    • Measure the diameter of the cap and socket to make sure they are the correct size.
    • There are two common sizes of snap, as pictured here. Be sure that you have the correct one.
  3. Installing a Plastic Snap Using a Hand Press: 3 단계, 이미지 1/3 Installing a Plastic Snap Using a Hand Press: 3 단계, 이미지 2/3 Installing a Plastic Snap Using a Hand Press: 3 단계, 이미지 3/3
    • Insert the cap, rounded side down, into the cap fitting for the hand press. The shaft of the cap should face out.
    • The cap fitting is marked orange.
  4. Installing a Plastic Snap Using a Hand Press: 4 단계, 이미지 1/3 Installing a Plastic Snap Using a Hand Press: 4 단계, 이미지 2/3 Installing a Plastic Snap Using a Hand Press: 4 단계, 이미지 3/3
    • Insert the stud into the stud fitting for the hand press. The widest part of the stud should be facing out. When seated correctly, the stud should snap into place and sit in the fitting without being held.
    • The stud fitting is marked green.
  5. Installing a Plastic Snap Using a Hand Press: 5 단계, 이미지 1/3 Installing a Plastic Snap Using a Hand Press: 5 단계, 이미지 2/3 Installing a Plastic Snap Using a Hand Press: 5 단계, 이미지 3/3
    • Insert the cap fitting onto the fitting base of the hand press.
  6. Installing a Plastic Snap Using a Hand Press: 6 단계, 이미지 1/3 Installing a Plastic Snap Using a Hand Press: 6 단계, 이미지 2/3 Installing a Plastic Snap Using a Hand Press: 6 단계, 이미지 3/3
    • Insert the stud fitting into the upper fitting holder of the hand press.
    • Insert the fitting as far as it will go, so that the only visible part is the wider encasement portion of the fitting.
    • Tighten the screw on the side of the upper fitting holder to secure the stud fitting. Tighten the screw about a 1/4 turn past finger-tight.
  7. Installing a Plastic Snap Using a Hand Press: 7 단계, 이미지 1/2 Installing a Plastic Snap Using a Hand Press: 7 단계, 이미지 2/2
    • Slowly pull the handle on the hand press to test the range of the fittings.
    • The fittings should just touch when the handle is pulled to its maximum.
    • If there is a gap in the fittings, adjust the height of the fitting base on the hand press by turning it until the fittings touch.
  8. Installing a Plastic Snap Using a Hand Press: 8 단계, 이미지 1/2 Installing a Plastic Snap Using a Hand Press: 8 단계, 이미지 2/2
    • Mark the fabric where you will be inserting the snap.
    • Align the fabric in the hand press so that the mark rests directly above the shaft of the cap.
    • If the fabric is not laying flat, have a friend pull the fabric taut to help keep it flat as you insert the snap.
    • The cap is on the bottom of the press. Be sure that you place your fabric face down, so that the cap is on the correct side.
  9. Installing a Plastic Snap Using a Hand Press: 9 단계, 이미지 1/3 Installing a Plastic Snap Using a Hand Press: 9 단계, 이미지 2/3 Installing a Plastic Snap Using a Hand Press: 9 단계, 이미지 3/3
    • With the fabric aligned, pull the handle of the hand press down in one continuous motion.
    • Setting a plastic snap requires little force. You will need to pull hard enough to get the press to its maximum range, but not beyond that.
  10. Installing a Plastic Snap Using a Hand Press: 10 단계, 이미지 1/2 Installing a Plastic Snap Using a Hand Press: 10 단계, 이미지 2/2
    • Release the handle of the hand press, and remove the fabric.
    • Inspect both sides of your snap to make sure that it is laying flat and tight up against the fabric. When you inspect the stud side you should see that the nose of the cap has been pressed into a ring; this is what holds the snap parts together.
    • If the snap is not set all the way, reinsert it into the hand press, aligning it as it was before, and repeat step 9 of this guide.
  11. Installing a Plastic Snap Using a Hand Press: 11 단계, 이미지 1/2 Installing a Plastic Snap Using a Hand Press: 11 단계, 이미지 2/2
    • Get a new cap.
    • Get a new socket.
    • You will want the color to match on your components—we are using different colors to illustrate that this is a different component than before. If the snap you are replacing has colors on the front and back that differ from each other, then try to match those colors.
  12. Installing a Plastic Snap Using a Hand Press: 12 단계, 이미지 1/3 Installing a Plastic Snap Using a Hand Press: 12 단계, 이미지 2/3 Installing a Plastic Snap Using a Hand Press: 12 단계, 이미지 3/3
  13. Installing a Plastic Snap Using a Hand Press: 13 단계, 이미지 1/3 Installing a Plastic Snap Using a Hand Press: 13 단계, 이미지 2/3 Installing a Plastic Snap Using a Hand Press: 13 단계, 이미지 3/3
    • Insert the socket into the socket fitting for the hand press. The widest part of the socket should be facing towards the fitting. When seated correctly, the socket should snap into place and sit in the fitting without being held.
    • The socket fitting is marked purple.
  14. Installing a Plastic Snap Using a Hand Press: 14 단계, 이미지 1/2 Installing a Plastic Snap Using a Hand Press: 14 단계, 이미지 2/2
  15. Installing a Plastic Snap Using a Hand Press: 15 단계, 이미지 1/3 Installing a Plastic Snap Using a Hand Press: 15 단계, 이미지 2/3 Installing a Plastic Snap Using a Hand Press: 15 단계, 이미지 3/3
    • Insert the socket fitting into the upper fitting holder on the hand press.
    • Tighten the screw on the side of the upper fitting holder to secure the socket fitting. Tighten the screw about a 1/4 turn past finger-tight.
  16. Installing a Plastic Snap Using a Hand Press: 16 단계, 이미지 1/3 Installing a Plastic Snap Using a Hand Press: 16 단계, 이미지 2/3 Installing a Plastic Snap Using a Hand Press: 16 단계, 이미지 3/3
  17. Installing a Plastic Snap Using a Hand Press: 17 단계, 이미지 1/2 Installing a Plastic Snap Using a Hand Press: 17 단계, 이미지 2/2
  18. Installing a Plastic Snap Using a Hand Press: 18 단계, 이미지 1/3 Installing a Plastic Snap Using a Hand Press: 18 단계, 이미지 2/3 Installing a Plastic Snap Using a Hand Press: 18 단계, 이미지 3/3
  19. Installing a Plastic Snap Using a Hand Press: 19 단계, 이미지 1/2 Installing a Plastic Snap Using a Hand Press: 19 단계, 이미지 2/2
    • Inspect both sides of your snap to make sure that it is laying flat and tight up against the fabric. When you inspect the socket side you should see that the nose of the cap has been pressed into a ring; this is what holds the snap parts together.
    • If the snap is not set all the way, reinsert the snap into the hand press, aligning it as it was before, and repeat step 18 of this guide.
결론
Admire your handiwork!
다른 3명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,113 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 5개
This is not a very helpful post as there are no sources for the tools needed and Patagonia support had no idea what I was talking about. They may not even have the replacement snap. Any further information would be gratefully appreciated.
Lorenzo Savona - 답글
Patagonia sent me some snaps to replace one that popped off a jacket. I do not have access to a hand press. any workarounds or suggestions would be helpful.
Matthew Steliga - 답글
Agree with the previous comments. A workaround for those without the exact sockets and the hand press would be appreciated…
Melissa Bryant - 답글
Joann’s and Michaels sell hand held snap tools and replacement snaps. Any snap can be used for a replacement snap, doesn’t have to be Patagonia specific, hope this helps!
rblgrlmle - 답글
Sort of misleading fix. You can get the replacement snaps from Patagonia and the hand press from Amazon but where do you get those very specific upper and lower sockets for the hand press that are shown? They certainly do not come with the hand press….
Craig Dodson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 16
30일 전: 61
전체 시간: 13,930
