주요 콘텐츠로 건너뛰기
JBL Charge 5 Buttons Replacement
필요한 것
  1. JBL Charge 5 Buttons Replacement, Fabric Case: 1 단계, 이미지 1/3 JBL Charge 5 Buttons Replacement, Fabric Case: 1 단계, 이미지 2/3 JBL Charge 5 Buttons Replacement, Fabric Case: 1 단계, 이미지 3/3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Buttons Replacement: 2 단계, 이미지 1/3 JBL Charge 5 Buttons Replacement: 2 단계, 이미지 2/3 JBL Charge 5 Buttons Replacement: 2 단계, 이미지 3/3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Buttons Replacement: 3 단계, 이미지 1/3 JBL Charge 5 Buttons Replacement: 3 단계, 이미지 2/3 JBL Charge 5 Buttons Replacement: 3 단계, 이미지 3/3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Buttons Replacement, Buttons: 4 단계, 이미지 1/2 JBL Charge 5 Buttons Replacement, Buttons: 4 단계, 이미지 2/2
    • Use an iFixit opening tool, to softly pry open each side of the button cover.
    • By removing the rubber button cover, the adhesives will break. This may cause the device to lose its waterproof feature.
  5. JBL Charge 5 Buttons Replacement: 5 단계, 이미지 1/3 JBL Charge 5 Buttons Replacement: 5 단계, 이미지 2/3 JBL Charge 5 Buttons Replacement: 5 단계, 이미지 3/3
    • Use a plastic spudger, and softly pry up on the sides of the button control board to remove it from the slot.
    • Be cautious and don't pull the board all of the way out. The board is connected to the device by a ribbon cable.
  6. JBL Charge 5 Buttons Replacement: 6 단계, 이미지 1/3 JBL Charge 5 Buttons Replacement: 6 단계, 이미지 2/3 JBL Charge 5 Buttons Replacement: 6 단계, 이미지 3/3
    • Pinch the no-fuss ribbon cable connector, and gently pull the cable out to disconnect it from the board.
    • Remove the button board.
결론
Kat Whaley
회원 가입일: 09/13/23
753 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 33
전체 시간: 161
