주요 콘텐츠로 건너뛰기
JBL Clip 2 Motherboard Replacement
필요한 것
  1. JBL Clip 2 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Motherboard Replacement: 2 단계, 이미지 1/1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Motherboard Replacement: 3 단계, 이미지 1/1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Motherboard Replacement: 4 단계, 이미지 1/1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Motherboard Replacement: 5 단계, 이미지 1/1
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Motherboard Replacement: 6 단계, 이미지 1/1
    • The motherboard is now exposed, and to extract it you must now desoder the eight connection points to the battery, audio AUX cord, and the Mic.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Michael Hong
회원 가입일: 02/01/17
1,014 평판
안내서 5개 작성하였습니다
UW Tacoma, Team 2-2, Rose Winter 2017 UW Tacoma, Team 2-2, Rose Winter 2017 회원
UWT-ROSE-W17S2G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 3,583
