주요 콘텐츠로 건너뛰기
JBL Clip 3 Motherboard Replacement
필요한 것
  1. JBL Clip 3 Motherboard Replacement, Speaker Grill: 1 단계, 이미지 2개 중 1개 JBL Clip 3 Motherboard Replacement, Speaker Grill: 1 단계, 이미지 2개 중 2개
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Motherboard Replacement, Speaker Housing: 2 단계, 이미지 2개 중 1개 JBL Clip 3 Motherboard Replacement, Speaker Housing: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 JBL Clip 3 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Motherboard Replacement, Carabiner Clip: 5 단계, 이미지 2개 중 1개 JBL Clip 3 Motherboard Replacement, Carabiner Clip: 5 단계, 이미지 2개 중 2개
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
  6. JBL Clip 3 Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 JBL Clip 3 Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to release the two cable connections from the motherboard.
    • The wires connecting to the battery are not very long, so be careful when removing them.
  7. JBL Clip 3 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the four screws.
  8. JBL Clip 3 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 JBL Clip 3 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the motherboard away from the speaker housing.
    • Desolder the two contact points.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Tyler Molden
회원 가입일: 03/28/22
497 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-5, Petersen Spring 2022 UMass Dartmouth, Team 1-5, Petersen Spring 2022 회원
UMASSD-PETERSEN-S22S1G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 27
지난 30일: 46
전체 시간: 1,225
