주요 콘텐츠로 건너뛰기
JBL Clip Plus Battery Replacement
필요한 것
  1. JBL Clip Plus Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $3.99
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Battery Replacement: 2 단계, 이미지 1개 중 1개
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Battery Replacement: 3 단계, 이미지 1개 중 1개
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Battery Replacement: 4 단계, 이미지 1개 중 1개
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Battery Replacement: 10 단계, 이미지 1개 중 1개
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
결론
다른 15명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Noah Pauk
회원 가입일: 02/08/16
809 평판
안내서 3개를 작성함
IUPUI, Team 3-4, Baechle Spring 2016 IUPUI, Team 3-4, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S3G4
4 회원들
안내서 6개를 작성함
16가이드 댓글
Is it possible if replaced with a battery from cellphones with higher AmH rating?
Patrick Ignacio - 답글
Unfortunately, it would be hard to find a cell battery this small. The original battery is 2" x 1 1/8" x 1/8". My samsung S3 battery is 2 1/2" x 2" x 3/16", so is far from fitting. If you were ok with shaving the molded battery holder down, you could probably fit one that's 2" x 1 1/2" x 1/4" or so (the thickness tolerance is hard to tell), but it would be a lot of work. I think I might just buy a speaker that has good battery reputation (i.e., NOT JBL).
Kael Lumen -
man need to replace the speaker were can i buy just that?
ruitherock - 답글
I think Id rather just buy a different speaker.
Lynne Norris - 답글
"No parts required."
Seriously? How about a new battery!
Also, mentioning the battery model or a link to a replacement battery would have been very useful.
Dan M - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 37
지난 30일: 177
전체 시간: 27,587
