주요 콘텐츠로 건너뛰기
JBL Clip Plus Microphone Replacement
필요한 것
  1. JBL Clip Plus Microphone Replacement, Battery: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $3.99
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Microphone Replacement: 3 단계, 이미지 1개 중 1개
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Microphone Replacement: 4 단계, 이미지 1개 중 1개
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Microphone Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Microphone Replacement: 6 단계, 이미지 1개 중 1개
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Microphone Replacement: 7 단계, 이미지 1개 중 1개
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Microphone Replacement: 8 단계, 이미지 1개 중 1개
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Microphone Replacement: 9 단계, 이미지 1개 중 1개
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Microphone Replacement: 10 단계, 이미지 1개 중 1개
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
  11. JBL Clip Plus Microphone Replacement, Microphone: 11 단계, 이미지 1개 중 1개
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Noah Pauk
회원 가입일: 02/08/16
809 평판
안내서 3개를 작성함
IUPUI, Team 3-4, Baechle Spring 2016 IUPUI, Team 3-4, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S3G4
4 회원들
안내서 6개를 작성함
1가이드 댓글
Love the sound of this speaker but I would like to disable the bluetooth signals. I only need and use the cable connection. I have contacted the manufacturer about this and they said the bluetooth cannot be disabled at the present set-up. Would you please show me how to disable or remove the bluetooth?
Mic - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 47
전체 시간: 2,136
