주요 콘텐츠로 건너뛰기
JBL Flip 3 USB Chip Replacement
필요한 것
  1. JBL Flip 3 USB Chip Replacement, USB Chip: 1 단계, 이미지 1/1
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 USB Chip Replacement: 2 단계, 이미지 1/1
    • Carefully remove outer frame to expose the inner components of the speaker.
  3. JBL Flip 3 USB Chip Replacement: 3 단계, 이미지 1/1
    • loosen the screws to remove the outer frame
  4. JBL Flip 3 USB Chip Replacement: 4 단계, 이미지 1/1
    • Remove the 8 8.9mm Phillips #00 screws to unfasten the side passive drivers. Set the screws and side passive drivers aside safely.
  5. JBL Flip 3 USB Chip Replacement: 5 단계, 이미지 1/1
  6. JBL Flip 3 USB Chip Replacement: 6 단계, 이미지 1/2 JBL Flip 3 USB Chip Replacement: 6 단계, 이미지 2/2
    • Remove the 3 pin connector from the USB chip.
  7. JBL Flip 3 USB Chip Replacement: 7 단계, 이미지 1/1
    • remove screws to expose usb port
결론
다른 49명이 해당 안내서를 완성하였습니다.
College Student
회원 가입일: 02/22/17
3,479 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Spring 2017 USF Tampa, Team S1-G2, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G2
5 회원들
안내서 17개 작성하였습니다
댓글 21개
how can i find the part..email me at leedeen2000@yahoo.com plz
leedeen2000 - 답글
I feel that the difficulty is just because of the lack of detail on the instructions. I also need to find the part, but where do I get it? I searched on eBay, Amazon and got nothing. That means that I have to scavenge this part from another one?
rodri.mendoza.t - 답글
i already got step 5, but i need know how i can get the replacement ? Any idea ?
PabloM - 답글
Looking for the part 2…
Daniel Brockbank - 답글
Looking for the same thing…
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 78
30일 전: 292
전체 시간: 61,157
