주요 콘텐츠로 건너뛰기
JBL Pulse 3 Outside Casing Replacement
필요한 것
  1. JBL Pulse 3 Outside Casing Replacement, Speaker Grill: 1 단계, 이미지 1개 중 1개
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 Outside Casing Replacement: 2 단계, 이미지 1개 중 1개
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 Outside Casing Replacement: 3 단계, 이미지 2개 중 1개 JBL Pulse 3 Outside Casing Replacement: 3 단계, 이미지 2개 중 2개
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 Outside Casing Replacement, Outside Casing: 5 단계, 이미지 2개 중 1개 JBL Pulse 3 Outside Casing Replacement, Outside Casing: 5 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
  5. JBL Pulse 3 Outside Casing Replacement: 6 단계, 이미지 2개 중 1개 JBL Pulse 3 Outside Casing Replacement: 6 단계, 이미지 2개 중 2개
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
  6. JBL Pulse 3 Outside Casing Replacement: 7 단계, 이미지 2개 중 1개 JBL Pulse 3 Outside Casing Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 Outside Casing Replacement: 8 단계, 이미지 1개 중 1개
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 Outside Casing Replacement: 9 단계, 이미지 2개 중 1개 JBL Pulse 3 Outside Casing Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
  9. JBL Pulse 3 Outside Casing Replacement: 10 단계, 이미지 2개 중 1개 JBL Pulse 3 Outside Casing Replacement: 10 단계, 이미지 2개 중 2개
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 Outside Casing Replacement: 11 단계, 이미지 1개 중 1개
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kaitlyn Greenfield
회원 가입일: 09/20/18
1,188 평판
안내서 6개를 작성함
4가이드 댓글
Wherr can I get or buy top ring for Pulse 3?
Mark Christian Mariñas - 답글
Please see our device page with the link to the manufacturer’s website. You should be able to find it there.
Kaitlyn Greenfield - 답글
I have one of these speakers, and as the delicate outer shell broke it seems nearly impossible to find a replacement…
Any chance to get spare parts in Europe? Thank you.
Raffaele T. - 답글
i'm also looking for it, did you find it?
Vladut Alexandru -
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 26
지난 30일: 112
전체 시간: 3,965
