주요 콘텐츠로 건너뛰기
JBL Xtreme Charging Port Replacement
필요한 것
  1. JBL Xtreme Charging Port Replacement, Cover: 1 단계, 이미지 1개 중 1개
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Charging Port Replacement: 2 단계, 이미지 2개 중 1개 JBL Xtreme Charging Port Replacement: 2 단계, 이미지 2개 중 2개
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Charging Port Replacement: 3 단계, 이미지 2개 중 1개 JBL Xtreme Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Charging Port Replacement, Bass Radiator: 4 단계, 이미지 3개 중 1개 JBL Xtreme Charging Port Replacement, Bass Radiator: 4 단계, 이미지 3개 중 2개 JBL Xtreme Charging Port Replacement, Bass Radiator: 4 단계, 이미지 3개 중 3개
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Charging Port Replacement: 5 단계, 이미지 3개 중 1개 JBL Xtreme Charging Port Replacement: 5 단계, 이미지 3개 중 2개 JBL Xtreme Charging Port Replacement: 5 단계, 이미지 3개 중 3개
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
  6. JBL Xtreme Charging Port Replacement, Charging Port: 6 단계, 이미지 3개 중 1개 JBL Xtreme Charging Port Replacement, Charging Port: 6 단계, 이미지 3개 중 2개 JBL Xtreme Charging Port Replacement, Charging Port: 6 단계, 이미지 3개 중 3개
    • Locate and disconnect the the three plugs indicated in these pictures.
  7. JBL Xtreme Charging Port Replacement: 7 단계, 이미지 2개 중 1개 JBL Xtreme Charging Port Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Unplug the three ports from the previous step.
    • A set of tweezers may be helpful to reach deeper into the device.
  8. JBL Xtreme Charging Port Replacement: 8 단계, 이미지 3개 중 1개 JBL Xtreme Charging Port Replacement: 8 단계, 이미지 3개 중 2개 JBL Xtreme Charging Port Replacement: 8 단계, 이미지 3개 중 3개
    • Locate the three Phillips head screws inside the zipper compartment and unscrew them.
    • Pull the zipper panel free from the device.
  9. JBL Xtreme Charging Port Replacement: 9 단계, 이미지 3개 중 1개 JBL Xtreme Charging Port Replacement: 9 단계, 이미지 3개 중 2개 JBL Xtreme Charging Port Replacement: 9 단계, 이미지 3개 중 3개
    • Under the zipper panel are eight more Phillips head screws. Unscrew them and carefully lift the battery cover.
    • Be careful not to damage the small white ribbon cable which connects the battery cover to the rest of the device.
  10. JBL Xtreme Charging Port Replacement: 10 단계, 이미지 2개 중 1개 JBL Xtreme Charging Port Replacement: 10 단계, 이미지 2개 중 2개
    • Unscrew the three 11.88mm Phillips head screws highlighted in the picture.
  11. JBL Xtreme Charging Port Replacement: 11 단계, 이미지 2개 중 1개 JBL Xtreme Charging Port Replacement: 11 단계, 이미지 2개 중 2개
    • Pull the Auxiliary board out.
    • There is foam covering the wires, making it difficult to remove the Auxiliary board. Take your time with this step.
  12. JBL Xtreme Charging Port Replacement: 12 단계, 이미지 3개 중 1개 JBL Xtreme Charging Port Replacement: 12 단계, 이미지 3개 중 2개 JBL Xtreme Charging Port Replacement: 12 단계, 이미지 3개 중 3개
    • The first image highlights the charging port.
    • Locate 6 metal pins highlighted in the second image and use a solder iron to disconnect the pins.
결론
다른 17명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Benny Huynh
회원 가입일: 02/15/17
2,031 평판
안내서 4개를 작성함
USF Tampa, Team 1-1, Sullivan Spring 2017 USF Tampa, Team 1-1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G1
4 회원들
안내서 28개를 작성함
2가이드 댓글
Please I have a JBL XTREME that sparks each time I plug it. What could be the cause
morris_ugwoke - 답글
Hi. Can someone advise where a replacement charging port can be sourced? I.e., so I can desolder the existing one and solder a new one in its place. The existing one is badly corroded so the unit won't charge. Thanks Andy
Andy R - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 32
지난 30일: 204
전체 시간: 26,328
