주요 콘텐츠로 건너뛰기
JBL Xtreme battery replacement
필요한 것
  1. JBL Xtreme battery replacement, Battery: 1 단계, 이미지 1/1
    • 8.4 V battery pack for the JBL Extreme.
  2. JBL Xtreme battery replacement: 2 단계, 이미지 1/1
    • Unscrew the screws and decover the shell.
  3. JBL Xtreme battery replacement: 3 단계, 이미지 1/1
    • Remove the battery pack by unscrewing the 8 screws. Unplug the battery pack. Drill a hole. Seal holes with hot glue because of air tightness.
  4. JBL Xtreme battery replacement: 4 단계, 이미지 1/2 JBL Xtreme battery replacement: 4 단계, 이미지 2/2
    • Solder up the connectors + and - . Use a DC hollow bush 5.5 x 2.1 for the current supply. Isolate the ends of the cables.
  5. JBL Xtreme battery replacement: 5 단계, 이미지 1/1
    • Battery 8,4 Volt. 13200mAh 8,4V Rechargeable Battery Pack Charger for Bicycle Light-XML-T6
  6. JBL Xtreme battery replacement: 6 단계, 이미지 1/1
    • Solarstorm 2S2P 18650 Battery Case.
    • 4xPanasonic NCR18650B 3,7V 3400mAh=14400 mAh
    • + 5V USB ON/OFF Button
결론
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Bert
회원 가입일: 06/27/17
217 평판
안내서 1개 작성함
6 댓글
hi
step 2: unscrew the screws …. thats th point, where are the screws. the body looks like glued.
stephan dingsda - 답글
Hi.
Don’t ask me, because I have this guide only translated not created. Try to contact the author on de.ifixit.com. I have translated it so, that I tried to don’t change the original text.
Martin
Martin Kubica - 답글
I didn’t get it quite clear: is there a original battery replacement or an improvised one? I am interested in replacing mine but I didn’t find the battery.
Chris Fotu - 답글
Hi.
See the comment higher.
Martin Kubica
Martin Kubica - 답글
WTF?!? Don’t do this. Buy a replacement battery online, and swap it out. Don’t drill holes, add glue, and try to cram in some battery that isn’t built for it!
fixit4 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 47
30일 전: 216
전체 시간: 25,966
