주요 콘텐츠로 건너뛰기
JD Razor 2000 Front Wheel Replacement
필요한 것
  1. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: 1 단계, 이미지 3개 중 1개 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: 1 단계, 이미지 3개 중 2개 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: 1 단계, 이미지 3개 중 3개
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
  2. JD Razor 2000 Front Wheel Replacement, Removing the Wheel: 2 단계, 이미지 1개 중 1개
    • Grip the bottom of the wheel and gently slide it out.
결론
작성자
1다른 기여자 명과 함께
Kaylan Naicker
회원 가입일: 10/14/14
255 평판
안내서 2개를 작성함
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G46
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 8
전체 시간: 1,135
