주요 콘텐츠로 건너뛰기
JD Razor 2000 Wheelie Bar Replacement
필요한 것
  1. JD Razor 2000 Wheelie Bar Replacement, Unscrewing the Axle Bolt: 1 단계, 이미지 1/2 JD Razor 2000 Wheelie Bar Replacement, Unscrewing the Axle Bolt: 1 단계, 이미지 2/2
    • Facing the wheelie bar as shown, place your left thumb on the bolt located on the left side of the back wheel and place the Allen wrench into the screw on the right side of the back wheel.
    • Using the wrench, slowly unscrew the bolt while applying constant pressure from the left side.
  2. JD Razor 2000 Wheelie Bar Replacement, Removing the Bolt and Bearing: 2 단계, 이미지 1/2 JD Razor 2000 Wheelie Bar Replacement, Removing the Bolt and Bearing: 2 단계, 이미지 2/2
    • Remove the bolt from the right side and the bearing from the left.
  3. JD Razor 2000 Wheelie Bar Replacement, Removing the Wheel: 3 단계, 이미지 1/1
    • Turn the JD Razor 2000 on its side as shown. Slowly remove the back wheel by pulling it out at a perpendicular angle to the scooter base.
  4. JD Razor 2000 Wheelie Bar Replacement, Pulling Out the Wheelie Bar: 4 단계, 이미지 1/1
    • Pull the wheelie bar away from the deck of the scooter.
결론
If you need more assistance, visit our troubleshooting guide here.
Shane
회원 가입일: 10/18/14
384 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G46
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 1,358
