주요 콘텐츠로 건너뛰기
Jabra CRUISER2 Motherboard Replacement
필요한 것
  1. Jabra CRUISER2 Motherboard Replacement, Front Plate: 1 단계, 이미지 1/1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • iOpener Instructions
  2. Jabra CRUISER2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Motherboard Replacement: 3 단계, 이미지 1/1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 Jabra CRUISER2 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Motherboard Replacement: 5 단계, 이미지 1/1
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the motherboard from the device by lifting it up from the back plate.
결론
Spartacus
회원 가입일: 10/17/14
636 평판
안내서 5개 작성하였습니다
Baylor, Team 8-13, Williams Fall 2014 Baylor, Team 8-13, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G13
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 762
