주요 콘텐츠로 건너뛰기
Jabra Freeway Antenna Replacement
필요한 것
  1. Jabra Freeway Antenna Replacement, Front Panel: 1 단계, 이미지 1/3 Jabra Freeway Antenna Replacement, Front Panel: 1 단계, 이미지 2/3 Jabra Freeway Antenna Replacement, Front Panel: 1 단계, 이미지 3/3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Antenna Replacement: 2 단계, 이미지 1/3 Jabra Freeway Antenna Replacement: 2 단계, 이미지 2/3 Jabra Freeway Antenna Replacement: 2 단계, 이미지 3/3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Antenna Replacement: 3 단계, 이미지 1/3 Jabra Freeway Antenna Replacement: 3 단계, 이미지 2/3 Jabra Freeway Antenna Replacement: 3 단계, 이미지 3/3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Antenna Replacement, Antenna: 4 단계, 이미지 1/2 Jabra Freeway Antenna Replacement, Antenna: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Carefully remove the rubber gasket using the tweezers.
  5. Jabra Freeway Antenna Replacement: 5 단계, 이미지 1/2 Jabra Freeway Antenna Replacement: 5 단계, 이미지 2/2
    • Remove the five 6mm T6 screws connecting the circuit board to the rear panel.
  6. Jabra Freeway Antenna Replacement: 6 단계, 이미지 1/3 Jabra Freeway Antenna Replacement: 6 단계, 이미지 2/3 Jabra Freeway Antenna Replacement: 6 단계, 이미지 3/3
    • Remove the microphone from microphone slot using tweezers.
  7. Jabra Freeway Antenna Replacement: 7 단계, 이미지 1/3 Jabra Freeway Antenna Replacement: 7 단계, 이미지 2/3 Jabra Freeway Antenna Replacement: 7 단계, 이미지 3/3
    • Excessive force may cause the circuit board to break, destroying the device.
    • Carefully use the plastic opening tool to lift the circuit board up.
    • The orange portion of the circuit board is glued into place, and a small amount of force is necessary to break it free from the adhesive.
  8. Jabra Freeway Antenna Replacement: 8 단계, 이미지 1/2 Jabra Freeway Antenna Replacement: 8 단계, 이미지 2/2
    • Use the tweezers to remove the antenna from the retaining clips.
  9. Jabra Freeway Antenna Replacement: 9 단계, 이미지 1/1
    • Desolder the antenna wire from the circuit board.
    • Please refer to the soldering technique guide for instructions on desoldering and soldering.
결론
Alec Wilson
회원 가입일: 10/19/16
741 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-8, Catania Fall 2016 UMass Dartmouth, Team 4-8, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G8
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 826
