소개
In this guide you will be replacing the microphone of the Jabra Freeway.
필요한 것
Desolder the two wires connecting to the microphone.
Please refer to the soldering technique guide for instructions on desoldering and soldering.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Perfect, thank you.
Based on my limited experience with this device, the component being replaced here is the secondary, or noise-cancelling microphone - not to be confused with the primary microphone. The other video showing replacement of the motion detector seems to be actually replacing the primary microphone.
