주요 콘텐츠로 건너뛰기
Jabra Freeway Motion Detector Replacement
필요한 것
  1. Jabra Freeway Motion Detector Replacement, Front Panel: 1 단계, 이미지 3개 중 1개 Jabra Freeway Motion Detector Replacement, Front Panel: 1 단계, 이미지 3개 중 2개 Jabra Freeway Motion Detector Replacement, Front Panel: 1 단계, 이미지 3개 중 3개
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
    • Remove the foam tape covering 2 hidden screws from the back of the device.
  2. Jabra Freeway Motion Detector Replacement: 2 단계, 이미지 3개 중 1개 Jabra Freeway Motion Detector Replacement: 2 단계, 이미지 3개 중 2개 Jabra Freeway Motion Detector Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Motion Detector Replacement: 3 단계, 이미지 3개 중 1개 Jabra Freeway Motion Detector Replacement: 3 단계, 이미지 3개 중 2개 Jabra Freeway Motion Detector Replacement: 3 단계, 이미지 3개 중 3개
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Motion Detector Replacement, Motion Detector: 4 단계, 이미지 3개 중 1개 Jabra Freeway Motion Detector Replacement, Motion Detector: 4 단계, 이미지 3개 중 2개 Jabra Freeway Motion Detector Replacement, Motion Detector: 4 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to lift the motion detector off the circuit board.
    • The motion detector is glued in place, so a moderate amount of force is required.
  5. Jabra Freeway Motion Detector Replacement: 5 단계, 이미지 1개 중 1개
    • Desolder the two wires connecting the motion detector to the circuit board.
    • Please refer to the soldering technique guide for instructions on desoldering and soldering.
결론
작성자
2다른 기여자 명과 함께
Alec Wilson
회원 가입일: 10/19/16
741 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-8, Catania Fall 2016 UMass Dartmouth, Team 4-8, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G8
2 회원들
안내서 6개를 작성함
1가이드 댓글
Based on my limited experience with this device, the component being replaced here is the primary microphone - not the motion detector as claimed. The other video showing replacement of the microphone is actually the secondary, or noise-cancelling microphone. I don’t know the exact components for the motion detector, but I’m quite sure that this is not that component.
Steve MacLeod - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 583
