주요 콘텐츠로 건너뛰기
Jabra Speak 510 Battery Replacement
필요한 것
  1. Jabra Speak 510 Battery Replacement, Outer Casing: 1 단계, 이미지 1/2 Jabra Speak 510 Battery Replacement, Outer Casing: 1 단계, 이미지 2/2
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the six 20 mm T6 screws from the bottom of the device.
    Remove the screws using T6 Torx screwdriver.
    Taha Asad - 답글
  3. Jabra Speak 510 Battery Replacement: 3 단계, 이미지 1/2 Jabra Speak 510 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Battery Replacement: 4 단계, 이미지 1/3 Jabra Speak 510 Battery Replacement: 4 단계, 이미지 2/3 Jabra Speak 510 Battery Replacement: 4 단계, 이미지 3/3
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
    The hooks on the plastic tabs point inwards. You can see the counterpart of a hook on the 2nd picture on the left of the battery.
    I released the hooks by pushing the plastic pads outwards, gently pulling a flat-head screwdriver towards the center. It is necessary to pull the screwdriver ca. 3mm back from the maximum possible depth (otherwise you would push the counterpart outwards, instead of the plastic pad).
    Franz - 답글
  5. Jabra Speak 510 Battery Replacement, Battery: 5 단계, 이미지 1/2 Jabra Speak 510 Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Once you have carefully separated the bottom case from the top case, locate the two batteries attached to the motherboard.
    • Notice that each battery has two wires, one red and the other black, soldered to the board. Make a careful note of which is soldered to which pad.
    • Desolder the battery connections using the heated soldering iron.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
  6. Jabra Speak 510 Battery Replacement: 6 단계, 이미지 1/1
    • The battery is glued to the motherboard. Take care not to damage it in any way with excessive force in removing it.
    • Carefully pry the battery away from the motherboard using a plastic opening tool. The glue gives very slowly under constant pressure and cannot be hurried. As the battery starts to lift you can insert the prying tool further as you continue to lift the battery.
    • The adhesive may still have sufficient stickiness to hold the new batteries, but if not, replace it with double sided tape.
    • Solder the wires of the new batteries to the board, making sure that the red and black go to the correct pads.
결론
다른 20명이 해당 안내서를 완성하였습니다.
Edgar Tavares
회원 가입일: 02/16/16
468 평판
안내서 1개 작성함
IUPUI, Team 2-3, Harley Spring 2016 IUPUI, Team 2-3, Harley Spring 2016 회원
IUPUI-HARLEY-S16S2G3
4 회원들
안내서 8개 작성하였습니다
댓글 9개
Thanks pal!
Freezing the headset in an airtight bag for 24 hours worked.
Best wishes,
Ronny
Norway
Ronny - 답글
Very precisely described steps, super well written - excellent job Ed, thanks
Rafael Benitez - 답글
Thank`s so much! Great job!
Artur Michalski - 답글
Very helpful. If I want to bypass the battery, how can I do? Thanks a lot.
Bruce.Hsu - 답글
Is it possible to change the USB cable?
publicidad publicidad - 답글
Power button on and then after immidiately off , please inform which comblaint
Delbin - 답글
Where can I find more of the foam pad to put back on after I finish changing the battery?
Eric Arnott - 답글
Hello,
can somebody recommend a brand, a battery model or links where to purchase 2 of those batteries? I'm fine with voltage and capacity indications, but I'm wondering about the maximum dimensions which fit the jabra so that I can buy the correct ones.
Evidently, I would prefer better brands, but not sure what is feasible in regard to that.
thank you!
CL 101 - 답글
soo cool
this heled me a lot
keep doing this
Giuseppe Faienza - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 97
30일 전: 448
전체 시간: 30,680
