주요 콘텐츠로 건너뛰기
Jabra Speak 510 Motherboard Replacement
필요한 것
  1. Jabra Speak 510 Motherboard Replacement, Outer Casing: 1 단계, 이미지 1/2 Jabra Speak 510 Motherboard Replacement, Outer Casing: 1 단계, 이미지 2/2
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Motherboard Replacement: 3 단계, 이미지 1/2 Jabra Speak 510 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Motherboard Replacement: 4 단계, 이미지 1/3 Jabra Speak 510 Motherboard Replacement: 4 단계, 이미지 2/3 Jabra Speak 510 Motherboard Replacement: 4 단계, 이미지 3/3
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/2 Jabra Speak 510 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/2
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. Jabra Speak 510 Motherboard Replacement: 6 단계, 이미지 1/1
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
  7. Jabra Speak 510 Motherboard Replacement: 7 단계, 이미지 1/2 Jabra Speak 510 Motherboard Replacement: 7 단계, 이미지 2/2
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jordan Murphy
회원 가입일: 02/16/16
717 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-3, Harley Spring 2016 IUPUI, Team 2-3, Harley Spring 2016 회원
IUPUI-HARLEY-S16S2G3
4 회원들
안내서 8개 작성하였습니다
댓글 3개
Great walk-through... thanks
Walaa Maher - 답글
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - 답글
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 17
30일 전: 76
전체 시간: 7,625
