주요 콘텐츠로 건너뛰기
Jawbone Big Jambox Speaker Replacement
필요한 것
  1. Jawbone Big Jambox Speaker Replacement, Outer Case: 1 단계, 이미지 1/1
    • Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
    • Due to interior clips holding the end caps in place, use caution when applying force.
  2. Jawbone Big Jambox Speaker Replacement: 2 단계, 이미지 1/3 Jawbone Big Jambox Speaker Replacement: 2 단계, 이미지 2/3 Jawbone Big Jambox Speaker Replacement: 2 단계, 이미지 3/3
    • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
    • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
    • Remove the three T6, 7.0 mm screws under each rubber tab.
    • Because the screws are a different length, set the screws aside.
  3. Jawbone Big Jambox Speaker Replacement: 3 단계, 이미지 1/3 Jawbone Big Jambox Speaker Replacement: 3 단계, 이미지 2/3 Jawbone Big Jambox Speaker Replacement: 3 단계, 이미지 3/3
    • With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
    • Unscrew indicated T6 9.7 mm screws.
    • Gently loosen the tabs from their anchor points so the bottom may be removed.
    • Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
  4. Jawbone Big Jambox Speaker Replacement: 4 단계, 이미지 1/1
    • Pry up the bottom panel by lifting from the device.
    • Pull the bottom up. This may take a bit of force as the bottom is glued to device.
    • Once removed, the battery will now be visible.
  5. Jawbone Big Jambox Speaker Replacement: 5 단계, 이미지 1/2 Jawbone Big Jambox Speaker Replacement: 5 단계, 이미지 2/2
    • Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates.
    • Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
  6. Jawbone Big Jambox Speaker Replacement: 6 단계, 이미지 1/1
    • Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
  7. Jawbone Big Jambox Speaker Replacement: 7 단계, 이미지 1/1
    • With the battery facing forward, remove the three indicated T6 9.5 mm screws.
    • Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
  8. Jawbone Big Jambox Speaker Replacement, Speaker: 8 단계, 이미지 1/3 Jawbone Big Jambox Speaker Replacement, Speaker: 8 단계, 이미지 2/3 Jawbone Big Jambox Speaker Replacement, Speaker: 8 단계, 이미지 3/3
    • Place the disassembled Jambox with the speakers facing up.
    • Locate the screws around the broken speaker.
    • Use a T15 screwdriver to remove the four 12.1 mm screws around the broken speaker.
  9. Jawbone Big Jambox Speaker Replacement: 9 단계, 이미지 1/1
    • Using a plastic opening tool, pry the speaker out of the Jambox.
  10. Jawbone Big Jambox Speaker Replacement: 10 단계, 이미지 1/2 Jawbone Big Jambox Speaker Replacement: 10 단계, 이미지 2/2
    • Desolder the wires from the speaker terminal in the Jambox.
    • Detach the round speaker from its square frame, and save the square frame for the replacement speaker.
    • Use caution when operating a soldering iron due to extreme heat.
    • For instructions on how to solder and desolder, take a look at the soldering guide.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Taryn Kelley
회원 가입일: 04/01/15
678 평판
안내서 1개 작성함
Cal Poly, Team 24-5, Lancaster Spring 2015 Cal Poly, Team 24-5, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G5
4 회원들
안내서 9개 작성하였습니다
댓글 14개
What is actual original speaker size and watts power?
Phinlander Betancur - 답글
Eu também gostaria de saber qual a potência e o tamanho exato do falante original para substituí-lo
I would also like to know the power and the exact size of the original speaker to replace it
francisnvieira - 답글
Does anyone know where to buy replacement speakers or for which they can be switched?
olivierdegruijter - 답글
@ Oliver,
I just wasted a pair of speakers because you mentioned those worked just fine for you. They are not the same sizes. it's smaller than the jamb speakers... On what basis you made that comment?
Kaveh Kadkhoda Zadeh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 34
30일 전: 122
전체 시간: 22,959
