주요 콘텐츠로 건너뛰기
Jazz Ultratab C954 Speaker Replacement
필요한 것
  1. Jazz Ultratab C954 Speaker Replacement, Back Cover: 1 단계, 이미지 1/2 Jazz Ultratab C954 Speaker Replacement, Back Cover: 1 단계, 이미지 2/2
    • On the top of the tablet there are two 1cm screws that hold the back cover on. Locate these screws and remove them using a Phillips head #0 screw driver.
  2. Jazz Ultratab C954 Speaker Replacement: 2 단계, 이미지 1/1
    • You now have to pry the back cover from the touch screen panel. To do this insert a plastic spudger into the seem. Then work your way around the panel until it is free.
    • There are buttons on the top side of the tablet that go through the back cover. The cover must slide up when removed to avoid damaging the buttons.
  3. Jazz Ultratab C954 Speaker Replacement: 3 단계, 이미지 1/1
    • This is what your tablet should look like once the back cover is removed. You are now ready to begin repairing your tablet. Follow the corresponding guide for instructions on repairing major components.
    • To reattach the back cover begin by sliding the cover on making sure the buttons and the speaker are in their designated holes on the back cover. Then attach the two covers by pressing them together until you hear the plastic tabs interlock.
    • With the two screens held together the last step is to put the two 1cm screws on the top of the tablet back in. Your tablet is now ready for use again!
  4. Jazz Ultratab C954 Speaker Replacement, Speaker: 4 단계, 이미지 1/1
    • With the back cover removed from your tablet locate the speaker and the speaker wires shown in the red box.
  5. Jazz Ultratab C954 Speaker Replacement: 5 단계, 이미지 1/1
    • Since the speaker is magnetically held to the screen of the tablet cutting the old wires will remove the old speaker.
    • Use caution when cutting the wires, you want to cut the wires as close to the motherboard as possible without harming the motherboard.
  6. Jazz Ultratab C954 Speaker Replacement: 6 단계, 이미지 1/2 Jazz Ultratab C954 Speaker Replacement: 6 단계, 이미지 2/2
    • Locate the positive and negative terminals of the speaker.
    • To attach the new speaker you must solder the new wires to the terminals on the motherboard. To do this hold the wire on the old solder, using a small amount of solder melt the solder and wires to the old connection points.
    • Soldering irons are very hot and can cause serious injury. If you do not know how to use a soldering iron please seek help from someone who is experienced.
    • For an explanation on soldering refer to iFixit's soldering guide How To Solder and Desolder Connections
  7. Jazz Ultratab C954 Speaker Replacement: 7 단계, 이미지 1/1
    • Your new speaker is now fully attached to the tablet ans should be operational. You can now reassemble the tablet. To do so refer to the back cover guide (step 3).
결론
Nicole Nault
회원 가입일: 03/25/15
413 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-7, Shastany Spring 2015 UMass Dartmouth, Team 1-7, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S1G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 159
