주요 콘텐츠로 건너뛰기
Jeans 2-Hole Button Replacement
필요한 것
  1. Jeans 2-Hole Button Replacement, 2-Hole Button: 1 단계, 이미지 1개 중 1개
    • Find a thread color that matches the fabric you are sewing the button on to.
  2. Jeans 2-Hole Button Replacement: 2 단계, 이미지 1개 중 1개
    • Loop the thread through the eye of the needle.
    • Tie a small knot around the eye of the needle with the thread.
    • Make sure the knot is tight!
  3. Jeans 2-Hole Button Replacement: 3 단계, 이미지 1개 중 1개
    • Thread the needle through the fabric from the inside out.
    • Tie a knot at the end of the thread after pulling most of it through the fabric.
  4. Jeans 2-Hole Button Replacement: 4 단계, 이미지 3개 중 1개 Jeans 2-Hole Button Replacement: 4 단계, 이미지 3개 중 2개 Jeans 2-Hole Button Replacement: 4 단계, 이미지 3개 중 3개
    • Sew the thread in a small 'x' where you would like to place the button.
    • If you don't want to sew, then mark the spot with a white fabric marker.
  5. Jeans 2-Hole Button Replacement: 5 단계, 이미지 3개 중 1개 Jeans 2-Hole Button Replacement: 5 단계, 이미지 3개 중 2개 Jeans 2-Hole Button Replacement: 5 단계, 이미지 3개 중 3개
    • Place the button over the small stitched 'x' or fabric marker spot.
    • Thread the needle through the left hole of the button from the inside out.
    • Pull the needle and thread all the way through the fabric.
    • If you can't find the hole of the button, thread the needle through the fabric first and then through the button hole.
  6. Jeans 2-Hole Button Replacement: 6 단계, 이미지 3개 중 1개 Jeans 2-Hole Button Replacement: 6 단계, 이미지 3개 중 2개 Jeans 2-Hole Button Replacement: 6 단계, 이미지 3개 중 3개
    • Cross the needle over to the right hole of the button.
    • Thread the needle all the way through the fabric.
    • This step creates the first stitch.
  7. Jeans 2-Hole Button Replacement: 7 단계, 이미지 1개 중 1개
    • Repeat Steps 6-7 four to five times, until you have a secure button.
  8. Jeans 2-Hole Button Replacement: 8 단계, 이미지 1개 중 1개
    • Create a thread shank on the inside of the fabric by looping the thread around a stitch.
    • Pull the thread all the way through the hole until it is tight.
    • Repeat this 2-3 times.
    • Tie a knot after the final stitch to secure the stitches.
  9. Jeans 2-Hole Button Replacement: 9 단계, 이미지 2개 중 1개 Jeans 2-Hole Button Replacement: 9 단계, 이미지 2개 중 2개
    • Use fabric scissors to cut off excess thread.
결론
After cutting the remaining thread, your button stays on your jeans.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Emily McKee
회원 가입일: 03/17/21
200 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 84
지난 30일: 176
전체 시간: 1,608
