주요 콘텐츠로 건너뛰기
Joy-Con 2 (Left) Joystick Replacement
필요한 것
  1. Joy-Con 2 (Left) Joystick Replacement, Remove the right edge screws: 1 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the right edge screws: 1 단계, 이미지 2개 중 2개
    • Use a tri‑point Y00 driver to remove the two 3.1 mm‑long black screws on the right edge of the controller.
  2. Joy-Con 2 (Left) Joystick Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 2개
    • Insert an opening pick into the gap underneath the bumper button on the left side of the controller, with a point of the pick pointing downwards.
    • Pry up to slightly lift the plastic strip running across the left edge of the controller.
  3. Joy-Con 2 (Left) Joystick Replacement, Separate the plastic strip: 3 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Separate the plastic strip: 3 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Separate the plastic strip: 3 단계, 이미지 3개 중 3개
    • Slide the opening pick around to the front of the controller.
    • Slide the opening pick down the plastic strip to separate the clips and adhesive securing it to the controller's body.
  4. Joy-Con 2 (Left) Joystick Replacement, Remove the plastic strip: 4 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the plastic strip: 4 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Remove the plastic strip: 4 단계, 이미지 3개 중 3개
    • Pry up on the bottom edge of the plastic strip with slow, steady force.
    • Repeat this prying action along the length of the strip until it's fully detached.
  5. Joy-Con 2 (Left) Joystick Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the plastic strip.
  6. Joy-Con 2 (Left) Joystick Replacement, Remove the left edge screws: 6 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the left edge screws: 6 단계, 이미지 2개 중 2개
    • Remove the two screws on the left edge of the controller:
    • One 3.1 mm‑long tri‑point Y00 black screw
    • One 3.0 mm‑long JIS 00 silver screw
    • You can use a Phillips screwdriver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they're the same size.
  7. Joy-Con 2 (Left) Joystick Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 3개
    • Don't try to remove the back cover yet.
    • Insert an opening pick into the gap between the front and back halves of the controller on its left side.
    • Slide the pick down the controller to disengage the clips.
    • Leave the opening pick at the bottom of the controller's left edge, just before its curve.
    • The opening pick will fall out once the back cover is removed. If it falls out before then, put it back to keep the two halves separated.
  8. Joy-Con 2 (Left) Joystick Replacement, Insert a second opening pick: 8 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Insert a second opening pick: 8 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Insert a second opening pick: 8 단계, 이미지 3개 중 3개
    • Hold the controller upside-down.
    • Insert a point of another opening pick next to the release button at the top of the controller.
    • Use the opening pick to press the release button through the gap.
  9. Joy-Con 2 (Left) Joystick Replacement, Release the back cover: 9 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Release the back cover: 9 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Release the back cover: 9 단계, 이미지 3개 중 3개
    • The back cover is connected to the controller by a cable at the bottom. Don't try to remove it completely yet.
    • While holding the release button with the opening pick, use your other hand to slide the back cover down to release the clips securing it to the controller's body.
    • Open the back cover.
  10. Joy-Con 2 (Left) Joystick Replacement, Remove the back cover: 10 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the back cover: 10 단계, 이미지 2개 중 2개
    • Firmly grasp the two wires (blue and white) above the rumble motor connector, located at the bottom of the controller's board, and pull the beige connector out of its socket.
    • Pulling the cable won't damage it, but don't dig your nails into the plastic sheathing.
    • Remove the back cover.
  11. Joy-Con 2 (Left) Joystick Replacement, Disconnect the battery: 11 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Disconnect the battery: 11 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Disconnect the battery: 11 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to firmly grip the white JST connector and pull straight away from its socket to disconnect it.
    • Once partially lifted, reposition your fingers/tweezers to beneath the connector's upper lip to increase your grip.
  12. Joy-Con 2 (Left) Joystick Replacement, Remove the release button: 12 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the release button: 12 단계, 이미지 2개 중 2개
    • Pick up the release button and remove it.
  13. Joy-Con 2 (Left) Joystick Replacement, Remove the trigger: 13 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the trigger: 13 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Remove the trigger: 13 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap between the bumper (L) and trigger (ZL) buttons at the top of the controller.
    • Pry up on the ZL button to pop it off and remove it.
    • You can lightly hold the ZL button with your finger to avoid launching it.
  14. Joy-Con 2 (Left) Joystick Replacement, Remove the screws: 14 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the screws: 14 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the two screws securing the release button mounting bracket:
    • One 3.9 mm‑long silver screw
    • One 6.2 mm‑long black screw
  15. Joy-Con 2 (Left) Joystick Replacement, Remove the bracket: 15 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the bracket: 15 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Remove the bracket: 15 단계, 이미지 3개 중 3개
    • Insert an opening pick underneath the release button bracket.
    • Pry it away from the controller to remove it.
  16. Joy-Con 2 (Left) Joystick Replacement, Remove the screws: 16 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the screws: 16 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the three 3.9 mm‑long silver screws securing the midframe.
  17. Joy-Con 2 (Left) Joystick Replacement, Remove the bumper: 17 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the bumper: 17 단계, 이미지 2개 중 2개
    • Hold the midframe lightly in place.
    • Pull the L bumper button off its mounting pegs and remove it.
    • The midframe will lift slightly when removing this button.
  18. Joy-Con 2 (Left) Joystick Replacement, Prop up the controller: 18 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Prop up the controller: 18 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Prop up the controller: 18 단계, 이미지 3개 중 3개
    • Use the back cover to prop up the controller while you work.
    • The buttons on the front of the controller should rest on the back cover's lip to keep it stable.
  19. Joy-Con 2 (Left) Joystick Replacement, Lift the trigger board: 19 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Lift the trigger board: 19 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the 3.9 mm‑long silver screw securing the trigger button board.
  20. Joy-Con 2 (Left) Joystick Replacement: 20 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 20 단계, 이미지 2개 중 2개
    • Insert the point of a spudger underneath the board, and lift it until it pops up.
  21. Joy-Con 2 (Left) Joystick Replacement, Remove the midframe: 21 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the midframe: 21 단계, 이미지 2개 중 2개
    • Pick up and remove the midframe.
  22. Joy-Con 2 (Left) Joystick Replacement, Disconnect the trigger board: 22 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Disconnect the trigger board: 22 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Disconnect the trigger board: 22 단계, 이미지 3개 중 3개
    • Use the point of a spudger to flip up the locking flap on the trigger button ZIF connector, located on the controller's board.
  23. Joy-Con 2 (Left) Joystick Replacement, Remove the trigger board: 23 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the trigger board: 23 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    • Remove the trigger button board.
  24. Joy-Con 2 (Left) Joystick Replacement, Disconnect the joystick: 24 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Disconnect the joystick: 24 단계, 이미지 2개 중 2개
    • Use the point of a spudger to flip up the locking flap on the joystick cable ZIF connector, located in the center of the board.
  25. Joy-Con 2 (Left) Joystick Replacement: 25 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 25 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to grab the brown part of the cable and gently pull the cable out of its socket.
  26. Joy-Con 2 (Left) Joystick Replacement, Remove the board screws: 26 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the board screws: 26 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the five 3.1 mm‑long black screws securing the board to the controller.
  27. Joy-Con 2 (Left) Joystick Replacement, Lift the board: 27 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Lift the board: 27 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Lift the board: 27 단계, 이미지 3개 중 3개
    • Insert the point of a spudger underneath the board, next to the joystick, between the board and the frame.
    • Pry up slowly on the board to lift it until you can grab it with your fingers.
    • The black tape stuck to the joystick will stay with the board. Work slowly to avoid tearing the tape.
  28. Joy-Con 2 (Left) Joystick Replacement: 28 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 28 단계, 이미지 2개 중 2개
    • Use your fingers or a spudger to lift the joystick cable up so it's perpendicular to the joystick module.
  29. Joy-Con 2 (Left) Joystick Replacement: 29 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 29 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement: 29 단계, 이미지 3개 중 3개
    • Lift the board and flip it over the controller's inner edge.
    • Be careful not to crease or tear the two ribbon cables connecting the board to the controller.
  30. Joy-Con 2 (Left) Joystick Replacement, Remove the joystick: 30 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the joystick: 30 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the two 3.9 mm‑long silver screws securing the joystick.
  31. Joy-Con 2 (Left) Joystick Replacement: 31 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 31 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to pick up and remove the joystick.
  32. Joy-Con 2 (Left) Joystick Replacement, Disassembly complete: 32 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
  33. Joy-Con 2 (Left) Joystick Replacement, Install the joystick: 33 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the joystick: 33 단계, 이미지 2개 중 2개
    • Align the circular cut-out in the joystick's frame with the peg near the controller's inner edge.
    • Set the joystick in the controller. Gently wiggle the joystick to ensure it's fully seated.
  34. Joy-Con 2 (Left) Joystick Replacement: 34 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 34 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the two 3.9 mm‑long silver screws securing the joystick.
  35. Joy-Con 2 (Left) Joystick Replacement, Install the board: 35 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the board: 35 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the board: 35 단계, 이미지 3개 중 3개
    • Lower the board into the controller at an angle so it sits underneath the locking tab on the controller's inner edge.
    • Use a spudger to bend the joystick's ribbon cable so it's perpendicular with the joystick.
    • Lower the board so the joystick's ribbon cable routes through the joystick cut-out in the board.
  36. Joy-Con 2 (Left) Joystick Replacement: 36 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 36 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement: 36 단계, 이미지 3개 중 3개
    • Push the board towards the controller's inner edge (the side with the shoulder buttons) to prevent it from colliding with the joystick module.
    • Lower the board into the frame.
    • Use your finger or the flat end of a spudger to press the black tape onto the back of the joystick module.
  37. Joy-Con 2 (Left) Joystick Replacement: 37 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 37 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the five 3.1 mm‑long black screws securing the board to the controller.
  38. Joy-Con 2 (Left) Joystick Replacement, Connect the joystick: 38 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Connect the joystick: 38 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Connect the joystick: 38 단계, 이미지 3개 중 3개
    • Make sure the locking flap is flipped up on the joystick cable ZIF connector.
    • Insert the joystick ribbon cable into its ZIF connector until it's fully seated.
    • The brown portion of the cable should end at the golden line on the board.
    • Use your finger or a spudger to flip the locking flap down to secure the cable.
  39. Joy-Con 2 (Left) Joystick Replacement, Connect the trigger board: 39 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Connect the trigger board: 39 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Connect the trigger board: 39 단계, 이미지 3개 중 3개
    • Make sure the locking flap is flipped up on the trigger cable's ZIF connector.
    • Position the trigger button board so its ribbon cable is aligned with its ZIF connector on the board.
    • Use tweezers or your fingers to gently slide the ribbon cable into its ZIF connector.
    • Flip the locking flap down to secure the cable.
  40. Joy-Con 2 (Left) Joystick Replacement, Install the midframe: 40 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the midframe: 40 단계, 이미지 2개 중 2개
    • Align the midframe with its screw holes on the outer edge of the controller.
  41. Joy-Con 2 (Left) Joystick Replacement, Install the trigger board: 41 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the trigger board: 41 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the trigger board: 41 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to set the bottom edge of the trigger button board underneath the tab on the midframe.
    • Press the board into place so the black peg on the midframe protrudes through the hole on the bottom corner of the board.
  42. Joy-Con 2 (Left) Joystick Replacement: 42 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 42 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the 3.9 mm‑long silver screw securing the trigger button board.
  43. Joy-Con 2 (Left) Joystick Replacement, Install the bumper: 43 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the bumper: 43 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the bumper: 43 단계, 이미지 3개 중 3개
    • Align the two springs on the bumper with their two posts on the midframe, and press it into place.
    • The bumper is held in place by the front shell of the controller. If it falls out, ensure it's fully seated in the shell.
  44. Joy-Con 2 (Left) Joystick Replacement, Install the midframe screws: 44 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the midframe screws: 44 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the three 3.9 mm‑long silver screws securing the midframe.
  45. Joy-Con 2 (Left) Joystick Replacement, Install the bracket: 45 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the bracket: 45 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the bracket: 45 단계, 이미지 3개 중 3개
    • Align the release button bracket with its screw holes and set it in the frame so it snaps into place.
    • The corner with the protruding square should be facing the battery.
  46. Joy-Con 2 (Left) Joystick Replacement: 46 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 46 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the two screws securing the release button bracket:
  47. Joy-Con 2 (Left) Joystick Replacement, Install the trigger: 47 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the trigger: 47 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the trigger: 47 단계, 이미지 3개 중 3개
    • Align the trigger button with the top of the controller, with the ZL engraving facing out.
    • Set the trigger button onto its metal spring. Ensure the legs of the metal spring are seated properly in their channels on the midframe.
    • Press firmly on the trigger button to snap it into place.
    • Check that the metal stabilizer didn't fall out of position. If it did, remove the trigger, place it back into position, and try again.
  48. Joy-Con 2 (Left) Joystick Replacement, Install the release button: 48 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the release button: 48 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the release button: 48 단계, 이미지 3개 중 3개
    • Insert the release button into its bracket.
    • If the release pin doesn't stick out of the controller when the button is pressed, the button isn't installed correctly. Re-insert or flip the button and try again.
  49. Joy-Con 2 (Left) Joystick Replacement, Connect the battery: 49 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Connect the battery: 49 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Connect the battery: 49 단계, 이미지 3개 중 3개
    • Align the battery connector over its socket on the board.
    • Press down on the connector until it's fully seated.
  50. Joy-Con 2 (Left) Joystick Replacement, Connect the rumble motor: 50 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Connect the rumble motor: 50 단계, 이미지 2개 중 2개
    • Align the rumble motor connector to its socket on the bottom edge of the board and push down until it's fully seated to connect it.
  51. Joy-Con 2 (Left) Joystick Replacement, Install the back cover: 51 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the back cover: 51 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the back cover: 51 단계, 이미지 3개 중 3개
    • Use an opening pick to press and hold the release button.
    • Place the back cover over the controller body so the release button cutout is slightly below the release button.
    • The release button is held down when the release pin is protruding from the frame. If the release button falls out of position, put it back and try again.
    • Press and slide the back cover up until the cutout for the release button is aligned with the button itself.
    • Ensure the rumble motor wires (blue & white) are fully within the frame.
  52. Joy-Con 2 (Left) Joystick Replacement: 52 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 52 단계, 이미지 2개 중 2개
    • Remove the opening pick.
  53. Joy-Con 2 (Left) Joystick Replacement, Install the left edge screws: 53 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the left edge screws: 53 단계, 이미지 2개 중 2개
    • Install the two screws on the left edge of the controller:
  54. Joy-Con 2 (Left) Joystick Replacement, Install the plastic strip: 54 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the plastic strip: 54 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the plastic strip: 54 단계, 이미지 3개 중 3개
    • Align the clips on the plastic strip with their cut-outs on the controller body.
    • Insert the clips on the bottom edge first, then insert the rest so the plastic strip sits flush.
  55. Joy-Con 2 (Left) Joystick Replacement, Install the right edge screws: 55 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the right edge screws: 55 단계, 이미지 2개 중 2개
    • Use a tri‑point Y00 driver to install the two 3.1 mm‑long black screws on the right edge of the controller.
결론
You finished fixing your Joy-Con 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Joy-Con 2 Answers Community for help.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nick Schultz
회원 가입일: 03/24/24
36,897 평판
안내서 224개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 192
지난 30일: 805
전체 시간: 3,100
