주요 콘텐츠로 건너뛰기
Jura Drainage valve (2)
필요한 것
  1. Jura Drainage valve (2), Jura Drainage valve (2): 1 단계, 이미지 1/3 Jura Drainage valve (2), Jura Drainage valve (2): 1 단계, 이미지 2/3 Jura Drainage valve (2), Jura Drainage valve (2): 1 단계, 이미지 3/3
    • The brewing group has already been removed and disassembled. Now it's time for the drainage valve.
    • There will be many pictures
    • All you need a small flathead screwdriver.
  2. Jura Drainage valve (2): 2 단계, 이미지 1/3 Jura Drainage valve (2): 2 단계, 이미지 2/3 Jura Drainage valve (2): 2 단계, 이미지 3/3
    • Images front and back
  3. Jura Drainage valve (2): 3 단계, 이미지 1/3 Jura Drainage valve (2): 3 단계, 이미지 2/3 Jura Drainage valve (2): 3 단계, 이미지 3/3
    • Pull off the clamp and pull out the inlet hose. At the end there is a seal, it often gets stuck in the drainage valve. Swap them out when reassembling.
  4. Jura Drainage valve (2): 4 단계, 이미지 1/3 Jura Drainage valve (2): 4 단계, 이미지 2/3 Jura Drainage valve (2): 4 단계, 이미지 3/3
    • Pull out the clip on the docking tube
    • Pry out the valve body. Make sure the white cap slides out of its hole.
    • Detach the docking nozzle.
  5. Jura Drainage valve (2): 5 단계, 이미지 1/3 Jura Drainage valve (2): 5 단계, 이미지 2/3 Jura Drainage valve (2): 5 단계, 이미지 3/3
    • Detailed photos.
    • The position of the sealing rings are marked green in picture 3.
    • The sealing ring on the docking socket is marked in red in picture 2. It is especially important. It's a little thinner than the other two.
    • The brackets are marked in red.
  6. Jura Drainage valve (2): 6 단계, 이미지 1/3 Jura Drainage valve (2): 6 단계, 이미지 2/3 Jura Drainage valve (2): 6 단계, 이미지 3/3
    • Here all the parts of the valve.
  7. Jura Drainage valve (2): 7 단계, 이미지 1/1
    • Here is the entire valve in one picture
  8. Jura Drainage valve (2): 8 단계, 이미지 1/3 Jura Drainage valve (2): 8 단계, 이미지 2/3 Jura Drainage valve (2): 8 단계, 이미지 3/3
    • Reassembly
    • When assembling, make sure that the lips of the seals point to the pressure side, i.e. inward, and the flat side outward.
    • When installing, make sure that the pressure hose runs through the slot in the valve carrier.
결론
Follow the steps in reverse order to reassemble your device.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Schwarzstein
회원 가입일: 07/15/13
2,813 평판
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 33
30일 전: 210
전체 시간: 7,964
