소개
Your fully automatic coffee machine makes very loud noises when grinding the coffee beans?
When making coffee, does the coffee only come out in drips?
Then you may have a problem with the grinder of your Jura Impressa F50 fully automatic coffee machine.
These instructions are intended to help you get access to the grinder of your fully automatic coffee machine in order to service it or to replace it completely.
It consists of a total of 3 parts: opening the machine, removing the grinder and reassembly.
필요한 것
Remove the drip pan, tray and container for used coffee,...
... the water tank, ...
and the aroma protection cover.
Remove the lock washer on the axle for grinding degree adjustment using pliers.
다른 6명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
