주요 콘텐츠로 건너뛰기
Justin Bieber Concert Microphone On/Off Switch Replacement
필요한 것
  1. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: 1 단계, 이미지 1/2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Flathead 1.5 mm Screwdriver
    $5.49
    구매
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing batteries: 2 단계, 이미지 1/1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: 3 단계, 이미지 1/2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: 3 단계, 이미지 2/2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone On/Off Switch Replacement, Positioning device: 4 단계, 이미지 1/1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: 5 단계, 이미지 1/2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: 5 단계, 이미지 2/2
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  6. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: 6 단계, 이미지 1/2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: 6 단계, 이미지 2/2
    • Remove the 2, #8 11.7 mm Phillips Head screws on the On/Off Switch Board
  7. Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: 7 단계, 이미지 1/2 Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: 7 단계, 이미지 2/2
    • Remove On/Off Switch Board from its holding and detach the wires.
    • Replace the On/Off Switch Board with a new one and reattach the wires using this soldering guide
결론
Mike Seyman
회원 가입일: 10/19/14
437 평판
안내서 4개 작성하였습니다
Baylor, Team 4-1, Williams Fall 2014 Baylor, Team 4-1, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 10
전체 시간: 163
