주요 콘텐츠로 건너뛰기
KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement
필요한 것
  1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: 1 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: 1 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: 1 단계, 이미지 3/3
    • Insert the key cap puller into the cracks around the keycap.
    • Twist the tool around the bottom of the keycap.
    • Hold the keyboard down, and pull on the keycap slowly.
    • Pull up as straight as possible.
    • Force required to pull a keycap may vary from soft to heavy.
  2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 2 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 2 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 2 단계, 이미지 3/3
    • Proceed to remove the surrounding keycaps.
  3. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 3 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 3 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 3 단계, 이미지 3/3
    • Flip the keyboard over so that the bottom is facing upward.
    • Slip an opening pick beneath the warranty sticker.
    • Proceed to pull the sticker off to reveal the hole.
  4. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 4 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 4 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 4 단계, 이미지 3/3
    • Use a Phillips #1 Screwdriver to remove the 10 mm screw.
  5. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 5 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 5 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 5 단계, 이미지 3/3
    • Slip an opening tool into the cracks at the indicated points.
    • Pry open carefully.
  6. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 6 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 6 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 6 단계, 이미지 3/3
    • Flip the keyboard so that the keys are facing upward.
    • Grab the sides of the top case and pull up gently.
  7. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 7 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 7 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 7 단계, 이미지 3/3
    • Separate the plate from the bottom case slightly.
    • Reach within and remove the daughterboard cable.
  8. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 8 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 8 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 8 단계, 이미지 3/3
    • Turn the plate over.
    • Locate the pins for the key switch.
    • All the key switches are labeled with their ASCII designation.
  9. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 9 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 9 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    구매
    • Desolder the pins with a soldering iron and a desoldering pump.
    • Repeat until the pins freely move inside the wells without heat.
    • Placing the soldering iron too close to the PCB may damage it.
  10. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 10 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 10 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 10 단계, 이미지 3/3
    • Wedge two opening tools under the key switch.
    • Pull up gently.
    • If the key switch appears to be immovable, consider repeating step 9.
  11. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 11 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 11 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 11 단계, 이미지 3/3
    • Insert a new key switch into the well with pins corresponding to that of the PCBs.
  12. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 12 단계, 이미지 1/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 12 단계, 이미지 2/3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 12 단계, 이미지 3/3
    • Solder the pins onto the PCB ensuring the solder stays within the wells of the pins.
    • Ensure the pins do not freely move after soldering.
    • Ensure that there is no solder connecting the two pins, as this can possibly cause a short circuit.
결론
To reassemble your device, follow these instructions in reverse order starting at step 7.
다른 한 분이 해당 안내서를 완성하였습니다.
Kenny Nguyen
회원 가입일: 07/05/20
232 평판
안내서 1개 작성함
York University, Team S1-G40, Allen Summer 2020 York University, Team S1-G40, Allen Summer 2020 회원
YORK-ALLEN-SU20S1G40
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 41
전체 시간: 1,493
