주요 콘텐츠로 건너뛰기
Karcher Pressure Washers 15209900 2018 Motor Replacement
필요한 것
  1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Safety precautions: 1 단계, 이미지 3개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Safety precautions: 1 단계, 이미지 3개 중 2개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Safety precautions: 1 단계, 이미지 3개 중 3개
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • Unscrew the output hose from the pressure washer.
  2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the rubber strap: 2 단계, 이미지 3개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the rubber strap: 2 단계, 이미지 3개 중 2개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the rubber strap: 2 단계, 이미지 3개 중 3개
    • Unlatch and remove the yellow rubber strap.
  3. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the hand grip: 3 단계, 이미지 1개 중 1개
    • Use a T20 driver to remove the two 55mm-long screws securing the hand grip.
  4. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the hand grip: 4 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the hand grip: 4 단계, 이미지 2개 중 2개
    • Remove the hand grip from the extension bars.
  5. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the top panels: 5 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the top panels: 5 단계, 이미지 2개 중 2개
    • Use a T15 driver to remove the six screws securing the top black plastic panels on either side of the device.
  6. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the top panels: 6 단계, 이미지 3개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the top panels: 6 단계, 이미지 3개 중 2개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the top panels: 6 단계, 이미지 3개 중 3개
    • Remove the two plastic panels.
  7. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the plastic feet: 7 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the plastic feet: 7 단계, 이미지 2개 중 2개
    • Remove the two T15 screws securing the plastic feet—one screw on either side.
  8. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plastic feet: 8 단계, 이미지 3개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plastic feet: 8 단계, 이미지 3개 중 2개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plastic feet: 8 단계, 이미지 3개 중 3개
    • Unclip and remove the plastic feet.
  9. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the housing: 9 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the housing: 9 단계, 이미지 2개 중 2개
    • Use a T15 driver to remove the ten screws securing the housing halves together.
    • Remove the T15 screw underneath the wheel axle.
  10. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the housing: 10 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the housing: 10 단계, 이미지 2개 중 2개
    • Set the device on its side.
    • Lift the housing half away from the body.
    • If the housing half does not separate, check to make sure you removed all the body screws.
    • Remove the housing.
    • Screws may get stuck inside the plastic housing. Be careful not to lose any screws.
  11. Karcher Pressure Washers 15209900 2018 Motor Replacement, Release the cord strain relief: 11 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Release the cord strain relief: 11 단계, 이미지 2개 중 2개
    • Slide the power cord strain relief out its notch on the plastic housing.
  12. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor: 12 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor: 12 단계, 이미지 2개 중 2개
    • Lift the motor assembly out of the plastic housing and set it aside.
  13. Karcher Pressure Washers 15209900 2018 Motor Replacement, Reassembly tip: 13 단계, 이미지 3개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Reassembly tip: 13 단계, 이미지 3개 중 2개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Reassembly tip: 13 단계, 이미지 3개 중 3개
    • Reassembly tip: Use these images to help reassemble the housing back around the motor.
    • Make sure that all five bushings are in place.
    • In order for the housing to fit properly, the bushings must fit in their respective mounts.
    • Make sure that the yellow tube is properly notched onto the housing.
    • Make sure that the power cord strain relief sits correctly in the housing notch.
  14. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the electrical box cover: 14 단계, 이미지 1개 중 1개
    • Use a T20 driver to remove the four screws securing the electrical box cover.
  15. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box cover: 15 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box cover: 15 단계, 이미지 2개 중 2개
    • Lift the cover off of the electrical box.
  16. Karcher Pressure Washers 15209900 2018 Motor Replacement, Loosen the capacitor: 16 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Loosen the capacitor: 16 단계, 이미지 2개 중 2개
    • Tilt the capacitor upward slightly to gain access to the connectors.
  17. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unplug the capacitor: 17 단계, 이미지 3개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Unplug the capacitor: 17 단계, 이미지 3개 중 2개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Unplug the capacitor: 17 단계, 이미지 3개 중 3개
    • Use your fingers to pull each capacitor connector directly off of their spade plug.
  18. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the capacitor: 18 단계, 이미지 1개 중 1개
    • Remove the capacitor.
    • Reassembly note: The wires are non-polarized and can connect into either plug on the capacitor.
  19. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plate spring: 19 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plate spring: 19 단계, 이미지 2개 중 2개
    • Remove the plate spring from the electrical box.
  20. Karcher Pressure Washers 15209900 2018 Motor Replacement: 20 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement: 20 단계, 이미지 2개 중 2개
    • Pull the switch out of the electrical box.
    • Disconnect the four spade connectors from the the switch.
  21. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the switch: 21 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the switch: 21 단계, 이미지 2개 중 2개
    • Remove the switch.
    • Reassembly tip: Use the second photo as a reference to help you properly re-wire the switch.
  22. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the grounding screw: 22 단계, 이미지 1개 중 1개
    • Use a flat head screwdriver to remove the screw securing the ground wire in the electrical box.
  23. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the electrical box: 23 단계, 이미지 1개 중 1개
    • Use a T30 driver to remove the two bolts securing the electrical box to the motor assembly.
  24. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box: 24 단계, 이미지 3개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box: 24 단계, 이미지 3개 중 2개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box: 24 단계, 이미지 3개 중 3개
    • Lift the electrical box away from the motor assembly, taking care to feed the wires through the cutout.
    • Remove the electrical box.
  25. Karcher Pressure Washers 15209900 2018 Motor Replacement, Set the motor upright: 25 단계, 이미지 1개 중 1개
    • Set the motor assembly upright with the pump assembly on the top.
    • The pump assembly is filled with oil. This step prevents the oil from spilling out when you remove the pump.
  26. Karcher Pressure Washers 15209900 2018 Motor Replacement, Loosen the pump assembly: 26 단계, 이미지 1개 중 1개
    • Use a 13mm socket to remove the four long bolts holding the pump assembly to the motor.
    • Re-assembly tip: The bolts hold the pump under pressure against the motor assembly. During reassembly, gradually tighten the bolts in a cross pattern.
  27. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the pump assembly: 27 단계, 이미지 2개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the pump assembly: 27 단계, 이미지 2개 중 2개
    • Lift the pump assembly off of the motor.
  28. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the pump oil: 28 단계, 이미지 1개 중 1개
    • Pour the pump oil out of the motor housing. If the oil looks serviceable, save it for reassembly.
    • Reassembly tip: The piston assembly is sealed with oil, and the motor housing acts as an oil pan. Before you attach the pump to the motor, fill the piston well with oil, up to the bearing plate.
  29. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the bearing plate: 29 단계, 이미지 1개 중 1개
    • Remove the bearing plate from the motor assembly.
    • Reassembly tip: The side of the plate with the ringed groove should face the bearings.
  30. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the bearing ring: 30 단계, 이미지 1개 중 1개
    • Remove the bearing ring.
  31. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor bushings: 31 단계, 이미지 3개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor bushings: 31 단계, 이미지 3개 중 2개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor bushings: 31 단계, 이미지 3개 중 3개
    • Pull the two rubber bushings off of each side of the motor.
  32. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor cover: 32 단계, 이미지 3개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor cover: 32 단계, 이미지 3개 중 2개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor cover: 32 단계, 이미지 3개 중 3개
    • Pull the black motor cover off of the motor assembly.
  33. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the blower wheel: 33 단계, 이미지 3개 중 1개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the blower wheel: 33 단계, 이미지 3개 중 2개 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the blower wheel: 33 단계, 이미지 3개 중 3개
    • Insert a pry bar or a flat head screwdriver between the blower wheel and the motor assembly.
    • Pry to loosen the blower wheel from the motor.
    • Slide the blower wheel off of the motor assembly.
  34. Karcher Pressure Washers 15209900 2018 Motor Replacement: 34 단계, 이미지 1개 중 1개
    • Only the motor assembly remains.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
283,126 평판
안내서 587개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,537개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 17
전체 시간: 3,182
