소개
Follow this guide to remove and replace the power switch module from the Karcher Vacuum Universal 14286230 2014.
필요한 것
The switch module should line up with the yellow plastic switch plunger.
The two plastic moulded discs line up using this black tab.
Unplug the wires from the switch. These are standard spade terminals that can be pulled apart.
Remove the switch.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
