주요 콘텐츠로 건너뛰기
Kenmore 400 Washer clutch band Replacement
필요한 것
  1. Kenmore 400 Washer clutch band Replacement, Clutch band: 1 단계, 이미지 3개 중 1개 Kenmore 400 Washer clutch band Replacement, Clutch band: 1 단계, 이미지 3개 중 2개 Kenmore 400 Washer clutch band Replacement, Clutch band: 1 단계, 이미지 3개 중 3개
    • Kenmore 400 washer that has difficulty spinning. It runs through the cycle but does not spin properly.
    • Open the lid
    • Remove cap from the agitator by using a flat tip screwdriver or similar.
  2. Kenmore 400 Washer clutch band Replacement: 2 단계, 이미지 3개 중 1개 Kenmore 400 Washer clutch band Replacement: 2 단계, 이미지 3개 중 2개 Kenmore 400 Washer clutch band Replacement: 2 단계, 이미지 3개 중 3개
    • With the cap removed, a 7/16 hex bolt becomes visible.
    • Use a socket wrench with 4 inch extension to remove the bolt.
    • The agitator bolt measures 5/16 X 1 inches, 24 thread size
  3. Kenmore 400 Washer clutch band Replacement: 3 단계, 이미지 3개 중 1개 Kenmore 400 Washer clutch band Replacement: 3 단계, 이미지 3개 중 2개 Kenmore 400 Washer clutch band Replacement: 3 단계, 이미지 3개 중 3개
    • With the bolt removed, pull the agitator of the shaft.
    • View of the drum with agitator removed
    • For ease of working on the bottom parts, lay the washer on its side.
  4. Kenmore 400 Washer clutch band Replacement: 4 단계, 이미지 3개 중 1개 Kenmore 400 Washer clutch band Replacement: 4 단계, 이미지 3개 중 2개 Kenmore 400 Washer clutch band Replacement: 4 단계, 이미지 3개 중 3개
    • Main parts of the assembly include
    • Drain pump
    • Motor
    • Transmission
    • This is a direct drive model. No belts but a motor coupler connects the motor to transmission. Check for any cracks etc.
    • Remove the wiring harness from the motor
  5. Kenmore 400 Washer clutch band Replacement: 5 단계, 이미지 3개 중 1개 Kenmore 400 Washer clutch band Replacement: 5 단계, 이미지 3개 중 2개 Kenmore 400 Washer clutch band Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the wiring harness from the clip on the transmission
    • Drain lines from the drum and drain hose are connected to the pump with spring clamps.
    • Using a pair of pliers and squeezinge the opposite ends of the clamps together will loosen the clamp.
  6. Kenmore 400 Washer clutch band Replacement: 6 단계, 이미지 3개 중 1개 Kenmore 400 Washer clutch band Replacement: 6 단계, 이미지 3개 중 2개 Kenmore 400 Washer clutch band Replacement: 6 단계, 이미지 3개 중 3개
    • Pull the drain hose of the pump
    • Remove the tub-to-pump hose the same way
    • Remove the three 1/2inch bolts.
  7. Kenmore 400 Washer clutch band Replacement: 7 단계, 이미지 3개 중 1개 Kenmore 400 Washer clutch band Replacement: 7 단계, 이미지 3개 중 2개 Kenmore 400 Washer clutch band Replacement: 7 단계, 이미지 3개 중 3개
    • Here are the three bolts. They are 5/16 by 11/16 with a 1/2 inch hex head.
    • With the three bolts removed, pull the complete assembly out of the drum
    • With the assembly removed, the clutch is now completely visible.
  8. Kenmore 400 Washer clutch band Replacement: 8 단계, 이미지 3개 중 1개 Kenmore 400 Washer clutch band Replacement: 8 단계, 이미지 3개 중 2개 Kenmore 400 Washer clutch band Replacement: 8 단계, 이미지 3개 중 3개
    • It is not necessary to replace the whole clutch. For this repair only the clutch band needs to be replaced
    • Using a pair of pliers to compress the spring will loosen the clutch band.
    • Lift the clutch band out of the clutch housing
    • Clutch band removed. Replace with model specific part.
결론
다른 12명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
837,194 평판
안내서 123개를 작성함
18가이드 댓글
Would this repair fix a 80 series Kenmore washer with same problem of no high-speed spinning
Larry Simonetta - 답글
Possibly but it depends on what is going on with it. This one spun just sluggish and not „forcefull“ enough. It pretty much stopped spinning with a full load because of the weak clutch
oldturkey03 -
How much do it cost to repair it
Ralph Lingelbach - 답글
The complete repair kit was somewhere between USD $30-$40
oldturkey03 -
I'm a jack of all if I can get it out I can rebuild it im a maintenance man at chicken proscenium plant we got to fixs all of it
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 60
지난 30일: 283
전체 시간: 35,070
