소개
Is your screen frozen? Check out these troubleshooting steps if you have not already.
If you do in fact want to replace your LCD circuit board, then you are in the right place.
It should be noted that this replacement will require you to take apart your entire Kindle, but this guide will help you every step of the way.
필요한 것
At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
Run the tool along the seams to pry open the front panel.
Remove the two 2.5 mm Phillips Head screws using the T5 Torx screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
