소개
このガイドを使ってAmazon Kindle Fireのバッテリーを交換しましょう。
필요한 것
プラスチックの開口ツールをKindle Fireの右下コーナーに差し込みます。
ケースをこじ開け、Kindle Fire周囲に沿ってプラスチック製の開口ツールをスライドして、ケースを固定しているクリップを外します。
Kindle Fire本体の上側から本体下側をこじ開けると作業がしやすいです。(横から外す) 2つを引き離さずに2つに分けようとする力をかけすぎると、内側のタブにダメージを与えてしまう可能性があります。
プラスチックの開口ツールの先端を右側バッテリーせるとKindle Fireのフレームの間に差し込みます。
バッテリーをテコの原理のようにして、プラスチック開口ツールを端に沿って下ろし、フレームにバッテリーを固定している接着剤を剥がします。
デバイスを組み立て直すには、これらの手順と逆の順序に従ってください。
다른 80명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 12개
I'm usually intimidated by electronics when it comes time to pull off the back or something, so this guide was invaluable in my efforts to replace the battery. I found a great price ($28) on a replacement Kindle battery here: http://www.primelec.com/atl-tablet-eread...
Thanks again
great post, I came across http://bestbattery.biz/Amazon/189882-D01...
The batteries from bestbattery.biz tried and tested with us.
Used this guide to replace my battery. Sadly, it didn't fix the problem. The problem is with my charger connection. It is loose. I had hoped changing the battery and looking at the problem from the inside would resolve it. The charging connection is in it's own little housing. I considered opening the housing but I had no replacement parts to fix whatever may be wrong. I greatly appreciate the quality of this repair guide. There were no problems with tear down or putting back together. Thanks again!
Some kindles have a battery connection that "floats". The problem can be alleviated by soldering the charging port. There is an excellent video on YouTube that shows step by step, the process for soldering the charging port. Hope this helps!!!
Kindle Fire will not charge and when I wiggle the cord to charge the Kindle the light comes on but doesn't stay on. Tried a different cord still does not work. Where can I get another battery for the Kindle Fire. Please let me know or any Barnes and Noble bookstore or Staples, or Office Depot store where I can find a battery. Thanks Melony
