소개
Replacement guide for the micro USB charging port on a Kindle Fire HDX 7” tablet.
The home button and micro USB are part of the same ribbon cable and are replaced at the same time.
Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
다른 4명이 해당 안내서를 완성하였습니다.
