주요 콘텐츠로 건너뛰기
Kindle Fire HDX 7" Microphone Replacement
필요한 것
  1. Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: 1 단계, 이미지 1/3 Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: 1 단계, 이미지 2/3 Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: 1 단계, 이미지 3/3
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Microphone Replacement: 2 단계, 이미지 1/1
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Microphone Replacement, Rear Panel: 3 단계, 이미지 1/1
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Microphone Replacement: 4 단계, 이미지 1/2 Kindle Fire HDX 7" Microphone Replacement: 4 단계, 이미지 2/2
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Microphone Replacement: 5 단계, 이미지 1/1
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Microphone Replacement, Microphone: 7 단계, 이미지 1/2 Kindle Fire HDX 7" Microphone Replacement, Microphone: 7 단계, 이미지 2/2
    • Pry up the left speaker with the flat end of a spudger and remove.
  7. Kindle Fire HDX 7" Microphone Replacement: 8 단계, 이미지 1/2 Kindle Fire HDX 7" Microphone Replacement: 8 단계, 이미지 2/2
    • Pry up the right speaker with the flat end of a spudger and remove.
  8. Kindle Fire HDX 7" Microphone Replacement: 9 단계, 이미지 1/3 Kindle Fire HDX 7" Microphone Replacement: 9 단계, 이미지 2/3 Kindle Fire HDX 7" Microphone Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Pry up the microphone connector from the rear panel with the flat end of a spudger.
    • Pull up on the microphone with a pair of tweezers to remove.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Blake Klein
회원 가입일: 01/29/17
71,016 평판
안내서 50개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 626
