주요 콘텐츠로 건너뛰기
Kindle Paperwhite 2nd Generation Charging Port Replacement
필요한 것
  1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Battery: 1 단계, 이미지 1/2 Kindle Paperwhite 2nd Generation Charging Port Replacement, Battery: 1 단계, 이미지 2/2
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
    • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
  2. Kindle Paperwhite 2nd Generation Charging Port Replacement: 2 단계, 이미지 1/2 Kindle Paperwhite 2nd Generation Charging Port Replacement: 2 단계, 이미지 2/2
    • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Charging Port Replacement: 3 단계, 이미지 1/1
    • Carefully remove the mid-frame from the back cover.
  4. Kindle Paperwhite 2nd Generation Charging Port Replacement: 4 단계, 이미지 1/2 Kindle Paperwhite 2nd Generation Charging Port Replacement: 4 단계, 이미지 2/2
    • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
  5. Kindle Paperwhite 2nd Generation Charging Port Replacement: 5 단계, 이미지 1/1
    • Carefully lift the battery and remove it from the device.
  6. Kindle Paperwhite 2nd Generation Charging Port Replacement, Motherboard: 6 단계, 이미지 1/2 Kindle Paperwhite 2nd Generation Charging Port Replacement, Motherboard: 6 단계, 이미지 2/2
    • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
    • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
  7. Kindle Paperwhite 2nd Generation Charging Port Replacement: 7 단계, 이미지 1/2 Kindle Paperwhite 2nd Generation Charging Port Replacement: 7 단계, 이미지 2/2
    • Gently disconnect the zif connectors.
    • Some of these connectors are very thin and fragile, handle with care!
  8. Kindle Paperwhite 2nd Generation Charging Port Replacement: 8 단계, 이미지 1/3 Kindle Paperwhite 2nd Generation Charging Port Replacement: 8 단계, 이미지 2/3 Kindle Paperwhite 2nd Generation Charging Port Replacement: 8 단계, 이미지 3/3
    • Gently remove the motherboard.
  9. Kindle Paperwhite 2nd Generation Charging Port Replacement, Charging Port: 9 단계, 이미지 1/1
    • The charging port is integrated in to the device motherboard.
    • From here, to fix a faulty port, either replace the entire motherboard, or carefully desolder the old port and solder a new one on in its place.
    • Check out the soldering guide for help.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Tyler Davis
회원 가입일: 09/15/16
1,598 평판
안내서 5개 작성하였습니다
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G2
4 회원들
안내서 7개 작성하였습니다
댓글 9개
How to replace the USB port; replace the motherboard. Kind of a lame fix if you ask me. Whatever happened to soldering a new port on?
Sam Hardeman - 답글
I have not done the fix yet but plan to replace the USB which appears to be a USB - micro B USB 2.0 Receptacle Connector 5 Position Surface Mount available at DigiKey. Is there any reason not to attempt this? I have microscope and soldering station. If not, where do you get the motherboard and how much is it?
Bill Smith - 답글
Any updates? Did you run into any issues?
theend12212012 -
Démontage facile effectivement, mais les cinq microsoudures sur la carte mère sont impossibles à faire avec un simple fer à souder ! Il faut utiliser du matériel pour CMS (composant à montage en surface)…
Ceci dit mon problème vient effectivement de ces microsoudures. En appuyant simplement sur ces contacts mon Kindle s’est remis en marche ! Vive le travail mal fait à la construction…
telerando - 답글
Getting the Kindle open and getting to the charging port was quite ‘easy’. In step 1 the top is stuck on with something like sticky back tape and the top can be gently pulled away from the tape.
Having got to the port I can not figure out how to replace it. This part does not seem to be easy, unless Step 9 is explained in much more detail. The contacts for the port seem to be incredibly small and I can’t figure out how they’re connected, or what part I need to order to replace the port.
Richard Garside - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 47
30일 전: 237
전체 시간: 24,999
