주요 콘텐츠로 건너뛰기
Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement
필요한 것
  1. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement, Disassembling Kinivo ZX100 Mini Portable Speaker: 1 단계, 이미지 1/1
    • Open the circular portion at the top of the speaker by twisting it until it reaches the maximum possible height.
    • Make sure it is twisted fully, as this will allow access to four screws to be removed in the next step.
  2. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: 2 단계, 이미지 1/2 Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: 2 단계, 이미지 2/2
    • Remove the four 12 mm Phillips screws from the enclosure.
  3. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: 3 단계, 이미지 1/2 Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: 3 단계, 이미지 2/2
    • Separate the resonator portion from the base of device to reveal the middle separator of the enclosure. The enclosure will now be in two pieces.
    • Hold the resonator portion of the enclosure gently aside to make sure there is no tension on the black and red wires coming from the bottom portion of the device.
    • Excessive force may disconnect the black and red speaker wires from the circuitry in the bottom portion of the device.
  4. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: 4 단계, 이미지 1/1
    • Separate the very bottom portion of the enclosure (marked in red) by pulling vertically on the red portion of the enclosure (marked in orange).
    • Gently set the very bottom portion and the resonator section aside once they have both been separated.
    • Remove the circuit board with your hands by lifting and sliding the board away from the LED indicator.
  5. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement, LED Indicator: 5 단계, 이미지 1/1
    • LED Locating
    • Locate the three, metal prongs found near the edge of the circuit board. They are found directly behind the LED light.
    • Soldering
    • If you are not familiar with the process of soldering, please refer to an online manual.
    • Heat the soldering iron to operating temperature.
    • Avoid touching the heated tip of the iron to ensure that you do not burn yourself.
  6. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: 7 단계, 이미지 1/2 Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Prong Removal
    • The picture in this step calls for speaker wire, but it can also be applied for the removal of each prong.
    • Remove a single prong by pulling it directly up from the circuit board using tweezers.
    • Repeat the previous until all three prongs have been removed.
  7. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: 8 단계, 이미지 1/1
    • Replacement
    • Obtain a new LED component from a manufacturer.
    • Perform the steps in reverse order to reconnect the new LED to the circuit board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matthew Kotce
회원 가입일: 03/29/15
266 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-5, Shastany Spring 2015 UMass Dartmouth, Team 1-5, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S1G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 314
