주요 콘텐츠로 건너뛰기
KitchenAid Classic Mixer K45SSWH Gasket Replacement
필요한 것
  1. KitchenAid Classic Mixer K45SSWH Gasket Replacement, Motor Housing Cover: 1 단계, 이미지 2개 중 1개 KitchenAid Classic Mixer K45SSWH Gasket Replacement, Motor Housing Cover: 1 단계, 이미지 2개 중 2개
    • Using a spudger, gently pry off the aluminum drip ring.
  2. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 2 단계, 이미지 1개 중 1개
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
  3. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 3 단계, 이미지 2개 중 1개 KitchenAid Classic Mixer K45SSWH Gasket Replacement: 3 단계, 이미지 2개 중 2개
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 4 단계, 이미지 1개 중 1개
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  5. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 5 단계, 이미지 1개 중 1개
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 6 단계, 이미지 2개 중 1개 KitchenAid Classic Mixer K45SSWH Gasket Replacement: 6 단계, 이미지 2개 중 2개
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
  7. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 7 단계, 이미지 2개 중 1개 KitchenAid Classic Mixer K45SSWH Gasket Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
  8. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside-down to prevent grease from leaking out.
  9. KitchenAid Classic Mixer K45SSWH Gasket Replacement, Gasket: 9 단계, 이미지 2개 중 1개 KitchenAid Classic Mixer K45SSWH Gasket Replacement, Gasket: 9 단계, 이미지 2개 중 2개
    • Use a butter knife or putty knife to remove grease from around the gasket.
    • Place grease in motor housing cover.
  10. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the gasket up with your hands or a spuger and remove it.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Joey Gavin
회원 가입일: 10/13/14
244 평판
안내서 1개를 작성함
Cal Poly, Team 14-28, Maness Fall 2014 Cal Poly, Team 14-28, Maness Fall 2014 회원
CPSU-MANESS-F14S14G28
4 회원들
안내서 22개를 작성함
댓글 2개
I got all the way to the last step of replacing the pin when i notice the mixer seemed to lock there in place and not move. What did i do wrong?
Dawn dawn6463@yahoo.com
Dawn Bennett - 답글
Hi there - There is a gasket around the engine part that you can see in step 7. Mine tore when I removed it. Is that a bad thing? I put the machine back together and it seems to work.
RES - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 123
전체 시간: 10,409
